Old 11-27-2016, 07:26 AM   #1
RobR'35
RobR'35's Avatar
Default Rear Axle Venting
One thing I've noticed on these Ford rear axles is they are not vented. Model T to 1948.
All later makes to today vent the rear axles.
Did all these earlier Ford axles vent in a way I'm not seeing?
RobR'35 is offline   Reply With Quote
Old 11-27-2016, 09:45 AM   #2
42merc
42merc's Avatar
Default Re: Rear Axle Venting
The venting process is through the torque tube via the transmission.
42merc is offline   Reply With Quote
Old 11-27-2016, 10:21 AM   #3
RobR'35
RobR'35's Avatar
You know I thought that at first but then there is a seal within the torque tube up by the drive shaft bearing/ speedo drive gear.
Old 11-27-2016, 10:27 AM   #4
RalphG
RalphG's Avatar
Does my 52 have a vent in the diff.? I just can't recall seeing one.
RalphG is offline   Reply With Quote
Old 11-27-2016, 10:49 AM   #5
51 MERC-CT
51 MERC-CT's Avatar
It vents thru the hollow bolt that holds the brake line 'T' fitting to the axle housing.
Old 11-27-2016, 10:58 AM   #6
JSeery
JSeery's Avatar
As stated, the torque tube rear axles have a much larger volume that allows more expansion than the later axles. When you convert a torque tube axle to an open drive it is a good idea to add a vent. I run a quick change and you really need the vent added to allow a pressure release as the gears heat up. Without a vent the axles tend to force gear lube past the axle seals and into/onto the brake drums.
Old 11-27-2016, 11:30 AM   #7
oldford2
oldford2's Avatar
When I installed a Mitchell in our 46 I had to add a rear end vent in addition to the vent that comes with the Mitchell..
oldford2 is offline   Reply With Quote
Old 11-27-2016, 01:05 PM   #8
Joe777
Joe777's Avatar
I've been pondering this exact topic recently. I was changing the rear axle gear lube in my 1.5 ton truck and noticed a venting of pressure when I removed the fill plug. The axle was at room temp (not warm from driving) when I did this. Does anyone make a vented fill plug for these bigger truck axles?
Joe777 is offline   Reply With Quote
Old 11-27-2016, 02:21 PM   #9
RalphG
RalphG's Avatar
Thanks,I should have remembered that as I must have had the block off when I replaced the brake line last year.
Old 11-27-2016, 04:12 PM   #10
Ross F-1
Ross F-1's Avatar
If the plug has NPT threads, it would be easy to get a hose nipple to replace it, and run a hose up to the frame.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 11-27-2016, 05:09 PM   #11
Karl Wolf
Karl Wolf's Avatar
I put a vent in the (closed) drive shaft housing. Close to middle.
I had tried to put a vent using the fill plug, and also at the side of one of the bells, using a drilled bolt.
All of these trials failed- oil came out.
I drilled the tube put a fitting and a small fuel filter on that.
Karl
Karl Wolf is offline   Reply With Quote
Old 11-27-2016, 05:36 PM   #12
JSeery
JSeery's Avatar
As Karl said, stay away from the center-section, it will throw oil out. Top of the axle housing is where I would put the vent. Run a tube (rubber hose) from the vent fitting to the height of the frame and then "J" it over. You don't want to pick up any water with the vent tube!
Old 11-27-2016, 08:48 PM   #13
RobR'35
RobR'35's Avatar
So all those years Ford didn't have one?
It didn't vent out some place......
Interesting.
Old 11-27-2016, 11:26 PM   #14
TomT/Williamsburg
TomT/Williamsburg's Avatar
I vented the driver side 36 bell in my avatar right wherexan 8 or 9" rear would be vented before I installed the open drive 3:54 center section using a vent from a 8 or 9" rear. I also drain the rear in my car every winter with all of the driving I do with it. Usually a 85-120 or so rear fluid works great for me ...
TomT/Williamsburg is offline   Reply With Quote
