01-17-2024, 06:20 PM | #1 |
Rear axle nut torque
I just torqued the axle nut on my rear axle to 200 ft/lbs and the cotter pin hole in the axle landed smack dab in the middle between two slots on the nut. The nut won't tighten any further (I set the torque wrench to 250 ft/lbs just to try to nudge it a little further but won't budge). Backing the nut off to where the cotter pin can be installed drops the torque to 100 ft/lbs.
What to do?
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
01-17-2024, 06:24 PM | #2 |
Re: Rear axle nut torque
Use a cheater bar to get it further, it will move. You never want to back it off for the cotter pin.
Alan |
01-17-2024, 06:27 PM | #3 |
A 180 grit da. Sticky paper on flat surface. Sand contact surface wash off blow dry and try again.
01-17-2024, 06:35 PM | #4 |
I just saw where Mart, back in 2020, recommended Philidas brand aircraft locking nuts (https://philidas.com/wp-content/uplo...nut-scaled.jpg) instead of the castellated nuts Ford uses to get the nut adequately tight and hold without a cotter pin.
Anyone else tried that? Looks like a good idea.
01-17-2024, 06:41 PM | #5 | |
(To be clear, the sanding is to be done on the backside of the nut.)
Alan |
01-17-2024, 08:09 PM | #6 |
Went down to the hardware store and got a couple of Grade 8 5/8" washers half as thick as the stock washer. Added them to the stack and got the hole lined up with the slots just fine at 250 ft/lbs of torque. Thanks for you help.
01-17-2024, 08:57 PM | #7 | |
