Old 03-09-2018, 09:50 PM   #1
Mike/Nebraska
Default Model B distributor
Does the B distributor use a different cap than an A? I didn't know about the slot for the timing lever on the A.
Mike/Nebraska is offline   Reply With Quote
Old 03-10-2018, 04:52 AM   #2
Leatherback
Default Re: Model B distributor
The B distributor uses the same as the Model A.
Bob
Leatherback is offline   Reply With Quote
Old 03-10-2018, 07:40 AM   #3
James Rogers
James Rogers's Avatar
The B cap has wires that plug in for later years but the early ones were like a Model A.
Old 03-10-2018, 09:55 AM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
Bob
The same, except the alignment notch is 90 degrees off from the Model A, so all later caps were made with 2 notches in order to fit both models.
