Old 04-11-2016, 11:18 PM   #1
RalphM
RalphM's Avatar
Default ID cyl head markings
Found this one cyl head with a mark I'd never seen before. What year/model is this from?
RalphM is offline   Reply With Quote
Old 04-11-2016, 11:19 PM   #2
RalphM
RalphM's Avatar
Default Re: ID cyl head markings
Ok for some reason it will only post the last picture.
Old 04-11-2016, 11:20 PM   #3
RalphM
RalphM's Avatar
Here's another
Old 04-11-2016, 11:21 PM   #4
RalphM
RalphM's Avatar
Odd combustion chamber shape,
But hey did you notice the pictures are upright!
Old 04-12-2016, 12:01 AM   #5
27lizzie
Any chance that it is a head for the 337 cu.in motor Just a shot in the dark.
Marlon
27lizzie is offline   Reply With Quote
Old 04-12-2016, 12:52 AM   #6
RalphM
RalphM's Avatar
No, same size as a 59AB head.
Old 04-12-2016, 07:10 AM   #7
jimTN
Looks like a 35 truck with flat pistons.
jimTN is offline   Reply With Quote
Old 04-12-2016, 08:39 AM   #8
rotorwrench
rotorwrench's Avatar
51T would be truck in or near 1935. In the prefixes the 5 would be the last digit of the year it was designed. The RH should be right hand side. On the other one, I don't know. 67 was not a common prefix number.
Old 04-12-2016, 09:18 AM   #9
Bruce Lancaster
67 is 1936 commercial...
51T MIGHT be a Canadian 1946 designation...I found some inconclusive suggestions of 1946 221 use in Canada, vague and not conclusive.
BUT...we don't know nuttin yet! How many stud holes, what sort of water outlet on the heads??
Bruce Lancaster is offline   Reply With Quote
Old 04-12-2016, 09:50 AM   #10
JM 35 Sedan
JM 35 Sedan's Avatar
What the others have already said, ..... plus a picture of the complete head would be a big help. That compression chamber is not that unique. I have some early 21 stud, wp's in heads, cylinder heads with that chamber configuration on both cast iron and aluminum.
John
Old 04-12-2016, 10:55 AM   #11
RalphM
RalphM's Avatar
Center water outlet, 24 stud.
Old 04-12-2016, 11:01 AM   #12
Bruce Lancaster
Eyeball the 51 T...could it be an 81T from worn mold?
Old 04-12-2016, 11:26 AM   #13
rotorwrench
That might be an 81T. Photographs are harder to tell thing like that. It would make more sense for a 24 stud head. The forming process for the cores wasn't always real accurate.
Old 04-12-2016, 12:10 PM   #14
tubman
tubman's Avatar
I think Bruce has it; The top stroke on the "5" looks quite rounded to me.
Old 04-12-2016, 12:32 PM   #15
flatjack9
flatjack9's Avatar
I agree, 81.
Old 04-12-2016, 02:28 PM   #16
RalphM
RalphM's Avatar
Now that makes sense!
