Old 04-10-2016, 11:15 AM   #1
robert dick
Default overdrives
from working on British cars half my life i have a few transissions laying around with Laycock overdrives, wondering id anyone has tried adapting one to a Ford tranny.
robert dick is offline   Reply With Quote
Old 04-11-2016, 07:17 AM   #2
KGS
KGS's Avatar
Default Re: overdrives
Check out this thread. In particular post #24.
http://www.fordbarn.com/forum/showth...olvo&showall=1
KGS is offline   Reply With Quote
Old 04-11-2016, 09:49 AM   #3
Kahuna
Kahuna's Avatar
I used a Gear Vendors unit (same as Volvo type). To me a better answer than one of those Mitchell units, as it is smaller, and electrically operated
Kahuna is offline   Reply With Quote
Old 04-11-2016, 10:10 AM   #4
JSeery
JSeery's Avatar
I have a gear vendor unit on a 65 Comet, do they make a unit for closed driveshafts?
Old 04-11-2016, 08:46 PM   #5
Kahuna
Kahuna's Avatar
Hi J
Gear Vendors themselves make these for a closed driveshaft application.
A friend in Colfax, CA has one in a 32 roadster and it works well
Mine is a bit different as I added the GV to the transmission
and have an open drive setup.
Can't seem to load a picture
Old 04-11-2016, 09:19 PM   #6
Kahuna
Kahuna's Avatar
Yes Robert, I have adapted one (a GV) to a Ford (Jeep) transmission.
Most however, adapt the Laycock type to the driveshaft, due to the
coupling issues
Any good machine shop should be able to help you out,
unless you are that capable. I am not
Jim
Old 04-11-2016, 09:41 PM   #7
JSeery
JSeery's Avatar
Hi J
Interesting, thank Kahuna.
Old 04-12-2016, 02:29 AM   #8
deucemac
deucemac's Avatar
They are kind of rare, but if you can find a Pacer, Gremlin, or Hornet overdrive transmission from '75-'77, they used a ford full syncro 3 speed trans with a Laycock type J overdrive. I have one in my roadster and it works flawlessly. I removed the side shift linkage and installed a Jeep T150 top shifter for an original look in the car.
deucemac is offline   Reply With Quote
Old 04-12-2016, 09:40 AM   #9
Milt/Las Vegas
Milt/Las Vegas's Avatar
I believe Gear Vendors make an adapter for that.
Milt/Las Vegas
Milt/Las Vegas is offline   Reply With Quote
