08-11-2013, 07:36 PM | #1 |
speedo gear No of teeth
Can anyone tell me the correct Speedo gear for a stock 1956 with a three speed and OD. Thanks
08-12-2013, 06:22 AM | #2 |
Re: speedo gear No of teeth
It depends on the tire size and rear gear ratio . My 56 has a 3.89 rear gear, most overdrive ones came with that. I think it is 21 but i haven't had it out for about 14 years.
You can go to www.gtsparkplugs.com and use their calculator . Click on " Automotive Calculators " then on "Speedometer Gear Size " .There are others online but theirs looked pretty easy to use. There is a drive gear and a driven gear in your transmission . Most of the time you are just needing the driven gear which can range from 16 to 22 , i'm guessing 21 or 22 , depending on what your rear gear and tire size is.___JIM__
64 Futura , bought new. 56 ford fairlane , bought about 30 years ago. 35 chevy street rod , started building in 2000. Last edited by Blue Futura; 08-12-2013 at 06:28 AM. |
08-22-2013, 09:08 PM | #3 |
Len ,my 56 t-bird 3 speed with overdrive and rear axle ratio of 3:31 uses a 22 teeth speedo gear...my car was an automatic which I converted to standard...J
08-22-2013, 10:36 PM | #4 |
Go over to the aaca site, there was just a discussion on this. I don't think any o/d car ever had a 3.31 so you might need an aftermarket gear adaptor.
http://forums.aaca.org/f225/56-t-bir...ns-356747.html |
08-23-2013, 06:15 AM | #5 |
64 Futura , bought new. 56 ford fairlane , bought about 30 years ago. 35 chevy street rod , started building in 2000. |
