07-04-2013, 07:17 PM | #1 |
Power steering pump needs help ....
1956 Merc power steering pump need rebuilding . Any Barners have any luck with anyone .*
I sure could use some recommendations . Thank you ......
"I can't cry as long as I know the Lord has risen " |
07-05-2013, 08:40 AM | #2 |
Re: Power steering pump needs help ....
Remove the pump and run one hose into the other to keep out dirt, and you can still use the car. Send it to Lares Corp. in Cambridge Mn. They will fix it like new for about a hundred bucks. 1-888-280-6386 or larescorp.com They do controll valves and cylinders too.
07-05-2013, 08:01 PM | #3 |
Ole Don thank you for the advise and lead, I need to start some were this pump is crying loud . Thanks again
08-12-2013, 07:47 PM | #4 |
No leaks before the rebuilds it was a must .....
