Old 10-20-2023, 08:45 AM   #1
31pickemup
31pickemup's Avatar
Default Lincoln Columbia in a Ford
Hey guys I’m new to Columbias so I have questions. I have a 39 deluxe coupe and want to install a Columbia. I have a guy that has a 39 Lincoln Columbia with all of the controls. Will it fit in a 39 deluxe? What modifications would I need to do? He wants $850 for it.
Wanted: 1934 Ford original Grille assembly!
31pickemup is offline   Reply With Quote
Old 10-20-2023, 09:55 AM   #2
47topless
47topless's Avatar
Default Re: Lincoln Columbia in a Ford
Give John a call. You may as well get correct information,
https://www.columbiatwospeedparts.com/index.cfm
BTW, that is a very good price for that unit if everything is in good shape.
47topless is offline   Reply With Quote
Old 10-20-2023, 01:08 PM   #3
Ken/Alabama
Ken/Alabama's Avatar
Internals are the same and they’re the same width.
This was discussed here a few months ago. Do a search for Lincoln Columbia then look for the topic Next winters Columbia project.
Old 10-20-2023, 06:31 PM   #4
mrtexas
mrtexas's Avatar
$850 is just the start. Much more to get them in top shape.
41 woodie https://41fordwoodie.weebly.com/
mrtexas is offline   Reply With Quote
Old 10-22-2023, 02:54 PM   #5
jimTN
The Lincoln rear ends are a 4.44 gear. The Columbia works well with a 4.11 for all around driving. Flat country a 3.78. The actual Lincoln center section is made differently than a Ford but the Columbia specific parts work with Ford parts.
Old 10-22-2023, 05:24 PM   #6
Old Magnet
Be aware that the Lincoln uses a wider spring and larger diameter spring shackle bolts
Old Magnet is offline   Reply With Quote
