Old 12-10-2020, 08:51 PM   #1
Vic in E-TN
Question Counterbalanced Crank with a harmonic balancer
There is another thread on the harmonic balancer from New Zealand. I do not want to hijack that thread so I started this one.
I have 2 engines that have counterbalanced cranks and they do not seem to have definite vibration ranges like some of the other posts indicated. I cannot think this through to see where the harmonic balancer would help. Anyone have any thoughts?
Vic
Vic in E-TN is offline   Reply With Quote
Old 12-10-2020, 09:51 PM   #2
Jack Shaft
Default Re: Counterbalanced Crank with a harmonic balancer
Torsional vibration is reduced with a counterbalanced crankshaft but not eliminated..why not run the balancer
Jack Shaft is offline   Reply With Quote
Old 12-10-2020, 10:26 PM   #3
GRutter
GRutter's Avatar
What other modifications did you do that could affect crank harmonics?
Lightened flywheel?
GRutter is offline   Reply With Quote
Old 12-10-2020, 10:53 PM   #4
Synchro909
Synchro909's Avatar
Lightened flywheel?
2 extra main bearings?
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 12-11-2020, 03:45 PM   #5
Pete
Pete's Avatar
Vic
You do not feel torsional vibration. The advantage of a front damper will normally only be noticed by longer bearing life.
Old 12-12-2020, 01:09 PM   #6
Jim Brierley
Pete is right!
Jim Brierley is offline   Reply With Quote
Old 12-13-2020, 05:13 AM   #7
SAJ
SAJ's Avatar
You can hear torsional vibration with metal timing gears which shake together as you pass through the harmonic rev ranges.
SAJ in NZ
SAJ is offline   Reply With Quote
