Old 12-18-2017, 04:17 PM   #1
B-O-B
B-O-B's Avatar
Default water pumps
Has anyone done a comparison on speedway VS Bob Drake water pumps foe a AB flathead. Speedway prices are about double Drakes & both say improved impeller & sealed bearings.
B-O-B is offline   Reply With Quote
Old 12-18-2017, 05:00 PM   #2
rotorwrench
rotorwrench's Avatar
Default Re: water pumps
The OEM ones used oiled bushings. These late reproductions are double row bearing and shaft equipped like the more modern ones so the bore is likely different. I doubt if there are a lot of sources for these and they may all come from the same source truth be known. The difference in price may be due to old stock setting on the shelf with older prices but I couldn't really tell you for sure. A lot of folks send their pumps to Skip Haney for his design of impeller. His overhaul prices are reasonable. A person has to have some cores though.
Old 12-18-2017, 05:08 PM   #3
Lawrie
Lawrie's Avatar
Drakes are out of stock on those pumps
Lawrie
Lawrie is offline   Reply With Quote
Old 12-18-2017, 05:14 PM   #4
1937sedandelivery
I just bought a pair from Joe's Antiques. I believe he gets them from Drakes and apparently had some in his inventory. Joe's prices are usually a littler better than Drakes.
gregg
1937sedandelivery is offline   Reply With Quote
Old 12-18-2017, 05:35 PM   #5
supereal
supereal's Avatar
Contact Skip Haney.1/941-505-9085 Good guy, good source for water pumps, coil rebuilds, distributors.
supereal is offline   Reply With Quote
Old 12-18-2017, 05:37 PM   #6
Angledrive
Angledrive's Avatar
Skips the guy, tech support is second to none
Angledrive is offline   Reply With Quote
Old 12-18-2017, 10:08 PM   #7
estout81
I've used Dennis Carpenter pumps for over 4 years and over 6K miles with no trouble. The pumps are on my '48 F-1.
estout81 is offline   Reply With Quote
Old 12-18-2017, 10:20 PM   #8
Ford Freak
Yep , me too !
Ford Freak is offline   Reply With Quote
Old 12-18-2017, 11:27 PM   #9
B-O-B
B-O-B's Avatar
I have Skips pumps & coils on my other 34 21 stud but didn't know that he was doing the 47 truck pumps with bearings. I do not have any cores.
Thanks all for your prompt replies.
Old 12-19-2017, 07:27 AM   #10
slowforty
slowforty's Avatar
I have both types Speedway and Drake. If you compare them Drake has a different design impeller. either one worked on my 40.
slowforty is offline   Reply With Quote
Old 12-19-2017, 09:02 AM   #11
adileo
adileo's Avatar
Another Carpenter with no issues!
Thanks
Andy
1952 F1
adileo is offline   Reply With Quote
Old 12-19-2017, 09:26 AM   #12
flat 39
flat 39's Avatar
After about 8 years, one of my speedway pumps started to leak. Replaced them with Drake pumps and they have been fine for the last 2 years.
flat 39 is offline   Reply With Quote
