Go Back   The Ford Barn > The Swap Meet > For Sale > Model-A
Old 07-28-2017, 12:51 PM   #1
Corn Fed
Corn Fed's Avatar
Default 30 Sport Coupe
City: State Center
State: IA
Price: 1500
30-31 Sport Coupe body: This is a body that is completely disassembled and comprised of sections from multiple cars. The quarters will need patches along the bottom edge. They have some dents on the top curves as well. The panel above the deck lid is from a coupe, but should be easy to convert by simply bending the edge over. There is no subframe except for a repro far rear cross brace. There are also some repro inner rear triangle pieces. The doors are the best part of the body. One is very nice with no rust. The other will need a lower outer patch installed because someone already started to cut it. There are all hinges except 1 lower body side. No decklid. The cowl will need a lower patch on at least one side. Uncut firewall. There is a gas tank, filler strip, “A” pillar covers, header panel, and above door trim pieces. I have some of the unique sport coupe top brackets and one of the “B” pillar covers. There is a pair of tweeked coupe “B” pillars, but I’ll include a nice pair of Sedan pillars that can be used instead. $1500 picked up. If someone wanted to turn this into a coupe, I have a complete coupe roof available for an additional $600.
No shipping. Delivery to HAMB Drags MIGHT be possible. Additional pics available.
Corn Fed is offline   Reply With Quote
