05-12-2015, 05:33 PM | #1 |
Thermostat or No Thermostat
I am running without a thermostat with a water temp of 185*. When I use a 160* thermostat I run at 190*. What is a normal, proper temp without a thermostat, and why would the thermostat not control the temp at 160*
Bill G |
05-12-2015, 05:52 PM | #2 |
Re: Thermostat or No Thermostat
mine runs 140 with a new bergs rad. without a stat
with a stat it runs 160 @80 deg ambient and thats with 3 holes drilled Last edited by Mitch//pa; 05-12-2015 at 06:02 PM. |
05-12-2015, 05:53 PM | #3 | |
"MAYBE" your radiator is PARTIALLY plugged, therefore the thermostat can't do the job it was designed to do, efficiently?? Bill W.
05-12-2015, 05:58 PM | #4 |
05-12-2015, 06:01 PM | #5 | |
To directly answer your question, one of my Model As has a new radiator and runs about 140 degrees depending on the outside temp. The other Model A has an older radiator and runs 160 degrees depending on outside temp. Neither of them uses a thermostat. |
05-12-2015, 07:02 PM | #6 |
05-12-2015, 07:14 PM | #7 |
I had trouble getting to 140 with out a thermostat.
