03-31-2015, 04:39 PM | #1 |
Extra Model A Parts
City:
Shrewsbury
State:
PA
Price:
various
Model A Parts for Sale
* parts unique to '28/'29 Fordor Leatherback body style *rear seat wood frame 55.00 *front seat wood frame 55.00 *front seat riser 30.00 *front seat side boards 20.00 ea *rear roof header 100.00 *left rear door opening post 75.00 *front seat to lock pillar fillers 10.00 ea *brackets - lock pillar to filler 10.00 ea *front seat floor pan 45.00 *left & right rear lower interior quarter panels - hardboard 20.00 ea *2 wire clips for drum style taillight support bracket 1.50 6v generator/short taper shaft w/ pulley - overhauled except coils 75.00 rear window shade mounting brackets 3.00 pr 1 window regulator handle with molded edges 6.00 emergency brake toggle lever - original style 12.00 heater valve for firewall 15.00 original style pitman arm w/ restored ball 17.00 license plat mounting bracket for drum taillight 15.00 clutch adjusting toggle - 5/16" thread 4.00 original style battery cable support bracket at flywheel housing 4.00 original windshield support lock knobs 3.00 pr original floorboard foot rest 2.00 rear brake camshafts - new 7.00 ea 2 LED turn signal bumper lights w/ mounting brackets - amber 12v 15 pr airmaze carb air filter assembly w/ metal screen 15.00 12v to 6v horn resistor 13.00 2 12v electronic turn signal flashers for LED turn signal system 6.00 ea main power disconnect switch bracket only - mounts on flywheel housing in engine compartment 4.00 '28-'29 emergency brake handle (mounts in front of transmission) to X-shaft rod 5.00 '30-'31 emergency brake handle (mounts on side of transmission) to X-shaft rod 16.00 '28-'29 firewall cowling webbing kit - original style 6.00 early cast gas shutoff valve handle 6.00 '28-'29 engine water outlet 10.00 Last edited by Bill Goddard; 07-01-2015 at 05:59 PM. Reason: removed items sold |
04-21-2015, 10:00 AM | #2 |
Re: Extra Model A Parts
