01-29-2018, 01:13 PM | #21 |
Re: Valve spring pressure and a Stipe cam
I've also used Isky springs on performance cams. They are very good but shorter so require a spacer of approx. .500", making them more difficult to install.
01-29-2018, 01:19 PM | #22 | |
In a stock A engine, with the light seat pressure originally used there, most any old A spring with correct measurements will run such engine at low rpm, likely forever. However, we expect more out of model A/B engines these days when they are warmed up / 'improved', so use the best valve spring that can be had, is my view and practice. New old stock LZ springs are excellent , as are Isky valve springs, in my experience. Nos flathead V8 springs have also proved consistent when checked for height/pressure, etc.... |
