03-05-2020, 12:36 PM | #1 |
what works?
What should I use to clean Edlebrock heads? I tried some aluminum cleaner and a scrub brush, it helps but does not bring them back to that new look. They are not the polished version but getting very tarnished. I did see someone once that had a spray on rinse off solution that worked effortlessly although I think it was some type of acid that might attack the engine paint or what ever else it contacts. Ken
03-05-2020, 01:28 PM | #2 |
Re: what works?
I used Semi Chrome to polish the primary cover and valve covers on my Harley.
Bruce
Works good Lasts long time |
03-05-2020, 01:54 PM | #3 |
Re: what works?
Have you tried FLITZ?
03-05-2020, 01:56 PM | #4 |
Re: what works?
Honda has a spray on product to clean aluminum.
Marvin Fagan 214-697-8430 |
03-05-2020, 03:16 PM | #5 |
Re: what works?
Just about any type of rubbing on the metal is going to remove the original cast or blasted surface.
03-05-2020, 06:22 PM | #6 |
Re: what works?
https://www.amazon.com/Valvoline-E30...omotive&sr=1-1
Tommy |
03-05-2020, 09:25 PM | #7 |
Re: what works?
For badly tarnished and stained aluminum heads I've found engine paint works best
03-05-2020, 09:38 PM | #8 |
Re: what works?
I bought a set of these fine wire brush tips for my Dremel tool and went to work. It worked great. Use the cup and pen shape for between the fins and around the head bolts and the wheel shaped ones for the big flat areas. Use medium speed on the Dremel tool, take your time, and expect to go through several tips. Make sure to wear glasses you don't want one of those fine steel bristles in your eye.
https://www.amazon.com/Drill-Warehou...GYAWF638FX7B4X Last edited by Zax40; 03-05-2020 at 09:57 PM. |
03-05-2020, 09:45 PM | #9 |
Re: what works?
"Zax40" - Do you use the brushes dry or with some compound or polish? If so, would you mind sharing?
03-05-2020, 09:59 PM | #10 |
Re: what works?
