Old 06-29-2014, 09:29 PM   #1
Craig E. Luton
Default radial tires
I am thinking of putting 600x16 radial tires on a 36 Ford pickup with original steering gear box. Does anyone know how the pickup would handle with the installed? Is this a good idea or not?
Thank you
Craig E. Luton is offline   Reply With Quote
Old 06-29-2014, 10:04 PM   #2
Brian
Brian's Avatar
Default Re: radial tires
The single best thing you will ever do to your 36 will be to fit radials!
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 06-29-2014, 11:09 PM   #3
tubman
tubman's Avatar
I absolutely agree. I did this on my '51, and it made all the difference in the world.
tubman is online now   Reply With Quote
Old 06-30-2014, 01:21 AM   #4
mike42
mike42's Avatar
I don't have a '36, but they sure made a big difference on my '40 Sedan. I went with Cokers and pretty happy with them. Good luck.
Mike
mike42 is offline   Reply With Quote
Old 06-30-2014, 06:55 AM   #5
36coupe3w
36coupe3w's Avatar
Thank you
Craig
I put Diamondbacks radials on my 36 3window & it most certainly improved handle & steering . I will never go back to bias tires
Bill
36coupe3w is offline   Reply With Quote
Old 06-30-2014, 07:22 AM   #6
Vic Piano
Vic Piano's Avatar
I run radial tires on all of our Flatheads except the '39 Lincoln Zephyr. Strangely, I find that the LZ handles better with the 7.00X16 six ply tires. When I got the LZ it had a set of G78X15 radials mounted on '47 Lincoln rims and I did not like the ride or handling however, 6.00X16 radials vastly improved the ride and handling on the '39 CS. I have 15 inch rims with various size radials on our '47 Convertible, '51 F-1 and '53 F-100 Panel Truck.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 06-30-2014, 08:23 AM   #7
Fibber Mcgee
Fibber Mcgee's Avatar
I have radials on my 49 and bias on my 41 and while I agree the radial eliminate the tendency to follow every ruthless in the road they make parking a pain. When parking with bias you feel like you have power steering but with radials you know you don't.
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. "
Fibber Mcgee is offline   Reply With Quote
Old 06-30-2014, 09:22 AM   #8
Vic Piano
Vic Piano's Avatar
I forgot to mention that I run the radials at 40psi, that makes them more user friendly when trying to park, parallel or otherwise...
