Old 07-16-2021, 11:30 AM   #1
Merc Cruzer
Merc Cruzer's Avatar
Default Electric power steering from a Saturn Vue into '54 Ford Customline
Just an FYI:
https://www.killbillet.com/forum/the...CUCgayMZsVtdps
Merc Cruzer is offline   Reply With Quote
Old 07-16-2021, 12:05 PM   #2
tubman
tubman's Avatar
Default Re: Electric power steering from a Saturn Vue into '54 Ford Customline
Very interesting. I would imagine it would require an update to 12 volts and an high amp alternator in the process.
Old 07-16-2021, 12:44 PM   #3
51 MERC-CT
51 MERC-CT's Avatar
Interesting adaptation but no mention was made on how the shifting of the transmission was addressed.
Did a little research and found that any column shift vehicle needed a new method of shifting gears.
In most cases a floor shift would be needed.
Old 07-16-2021, 05:35 PM   #4
Merc Cruzer
No holes cut in the tunnel for a standard transmission.
Old 07-16-2021, 06:20 PM   #5
51 MERC-CT
51 MERC-CT's Avatar
Not at the time the photo was taken.
And it appears to be an automatic equipped car (no clutch pedal)
Being a column shift, a way to shift will have to be addressed (such as a floor shift)
Old 07-16-2021, 09:05 PM   #6
Merc Cruzer
I asked and he sent me the latest picture.
File Type: jpg 219012161_4474385412594062_1457142415447451258_n.jpg (62.8 KB, 97 views)
Old 07-17-2021, 12:09 AM   #7
VeryTangled
VeryTangled's Avatar
Poetry...
-Jeff H
Have you thought about supporting the Early Ford V-8 Foundation Museum?
VeryTangled is offline   Reply With Quote
Old 07-17-2021, 08:14 AM   #8
Merc Cruzer
Further FYI: Computer controlled 5.0/AOD out of a '93 Mustang including factory EFI.
Old 07-18-2021, 10:59 AM   #9
flathead4rd
flathead4rd's Avatar
I'm looking for some information about using electric power steering on a 50 Ford with a flathead. Haven't had any luck yet. Already solved the shift problem with a T-5. Anyone?
flathead4rd is offline   Reply With Quote
Old 07-18-2021, 05:45 PM   #10
Angledrive
Angledrive's Avatar
https://www.fordbarn.com/forum/showt...power+steering
Angledrive is offline   Reply With Quote
Old 10-24-2021, 04:50 PM   #11
stegomo
stegomo's Avatar
there is a 3 part video on this on youtube using saturn vue power steering into a shoebox
stegomo is offline   Reply With Quote
Old 10-25-2021, 09:24 AM   #12
Kilohertz
Kilohertz's Avatar
I put a Toyota MR-2 (2001) PS system on my '49 F-47, works perfect...I'll try to find the thread detailing it. I was last winter.
Cheers
Here's mine detailed on the FTE site.
https://www.ford-trucks.com/forums/1...ing-build.html
1949 Ford F-47 with a '51 8BA Flatty, GM TBI fuel injection system, and a grey shop cat, Spot.
Kilohertz is offline   Reply With Quote
