Old 09-22-2020, 07:50 PM   #1
Steve in Denver
Steve in Denver's Avatar
Default '36 5 window, Wiper ARM installation
I looked through old threads, but did not find any answers.
How does one install the wiper arm on the vacuum wiper motor post?
I purchased the Dual wiper arms kit from Drake, looks good. There is a little wire that sticks out of the arm at 90 degrees. It goes in the little hole on the motor wiper arm. Drake says, "Easy to install". After an hour working on one, I tend to disagree.
First i inserted the wire through the hole, then I tried to slip the chrome cover over the arm. Haven't scratched my new paint yet, but it is not installed yet either.
I can't get the very long spring to compress inside the chrome cover arm. What is the trick?
Steve
Steve in Denver is offline   Reply With Quote
Old 09-24-2020, 11:14 AM   #2
CaliforniaBorn36
CaliforniaBorn36's Avatar
Default Re: '36 5 window, Wiper ARM installation
Place the cover over the spring, then push it up to compress the spring and put the upper end of the cover over the post. You have to tilt the arm out to be able to get the angle on the chrome cover to catch the post
CaliforniaBorn36 is offline   Reply With Quote
Old 09-24-2020, 02:51 PM   #3
Steve in Denver
Thanks, I'll try it again and let you know.
Old 09-24-2020, 03:51 PM   #4
Karl Wescott
Karl Wescott's Avatar
The wiper arm should have a spring loaded cover, with a "saddle" under the cover near the end.
The end of the arm goes into the hole in the shaft, the cover is then lifted (compressing the spring) until the saddle hooks over the groove.
Saddles are occasionally missing, and repro ones often have too small an id to seat on the shaft. If the saddle does not seat the notch can be opened by grinding or spreading, making sure the tabs seat correctly in the cover.
Karl Wescott is offline   Reply With Quote
Old 09-24-2020, 05:43 PM   #5
Steve in Denver
A BIG Thanks!!! Karl. That was the answer. I had the Saddle under the rod with the hole in it, and not on top as you show in your diagram. I did have to grid the small rod from the wiper arm off just a tad, less than the thickness of a dime, to get the cover to sit properly. I also made sure the saddle was in the grove in the wiper motor arm. Hopefully it will stay on at speed and not blow off in the wind.
Oh, do you mind if I send your drawing to Drake. Nothing came with their wiper assembly.
Steve in Denver
Old 09-24-2020, 06:24 PM   #6
Karl Wescott
If everything is seated correctly you should not have problems at a reasonable speed.
Go ahead and send it to Drake.
Old 09-24-2020, 06:29 PM   #7
Steve in Denver
Great, thanks.
