10-20-2019, 07:56 PM | #1 |
1936 Rumble Seat Rain drain
A previous owner installed the rumble seat in the '36 5 window that I now own. As the back third of the Trunk rain gutters are cut out, how did Henry reroute the rain gutters in an original car with a rumble seat?
I do know that the rain just drained down into the back area and there was a divider bar to keep the rain from supposedly coming forward and that it was to just drain out the two holes near the rear. I am making an aluminum pan to cover all the rust holes that now exist behind the rumble seat area. I will post pictures once it everything works. But if someone has pictures of how Henry did it, I would appreciate seeing them. |
10-21-2019, 12:42 AM | #2 |
Re: 1936 Rumble Seat Rain drain
Attached is a photo of the baffle plate used to remove water to the rear of the rumble seat area in the 35-36 Ford Coupe
10-21-2019, 01:36 AM | #3 |
My 35 3 window had no drain holes in that bottom panel, had to drill them myself. Luckily it had been in dry storage for many years so wasn't rusted out.
10-21-2019, 08:44 AM | #4 |
