Old 02-18-2015, 02:30 PM   #1
warren va
Question Replacing clutch assembly Question
When replacing clutch on a 40 convertible should I disconnect springs from the chassis by loosening the U bolts and leave springs attached to running gear or use a spreader and leave springs attached to the chassis ?
Thanks
Warren
warren va is offline   Reply With Quote
Old 02-18-2015, 02:59 PM   #2
Rich-CO
Default Re: Replacing clutch assembly Question
Warren---I always disconnect the spring from the cross-member.
Rich
Rich-CO is offline   Reply With Quote
Old 02-18-2015, 03:04 PM   #3
G.M.
That's what I do, get the U bolts out of the way, jack the frame up high enough , put the frame on jack stands and just roll it back on a floor jack under the rear. G.M.
www.fordcollector.com
Old 02-18-2015, 03:04 PM   #4
Kube
Kube's Avatar
Rich
I agree with Rich. Makes it a much easier task to leave the spring attached to the axle housings. Roll the entire rear axle/ torque tube, etc. rearwards about 6" - 8" and you will be all set to remove the transmission.
Old 02-18-2015, 03:59 PM   #5
Lawrie
Lawrie's Avatar
Still , be aware that the spring is then held together by iust the small centre bolt.
Lawrie
Lawrie is offline   Reply With Quote
Old 02-18-2015, 04:48 PM   #6
larrys40
Rich
I concur as well. I have removed and done this many times. the V8 spring does not have the same tension on it as a Model A spring. If you feel more comfortable wrap a chain and secure around both sides of the leaves. Pull rear axle back and remove trans from the top. Piece of cake...
Larry S.
larrys40 is offline   Reply With Quote
Old 02-18-2015, 06:37 PM   #7
warren va
Thanks everyone for your advise and prompt replies.
The reason I asked ,I was told the convertible has an X frame that is different than the standard 40 frame and that his would make it more complicated to remove the spring. Apparently not the case.
Thanks again;
Warren
Old 02-18-2015, 07:17 PM   #8
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
I find it almost easier to pull the engine, I don't have to roll around on a creeper. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 02-18-2015, 07:31 PM   #9
ford38v8
ford38v8's Avatar
But then, the creeper comes in handy for whenever your nap time is!
Alan
Thread Tools
Display Modes
