11-13-2013, 05:47 PM | #1 |
Generator front bearing re-pack?
Took my generator apart and cleaned it up as it was full of grease and dust. Front bearing
11-13-2013, 05:49 PM | #2 |
Re: Generator front bearing re-pack?
Was smooth and clean, what type of grease should I work into it as i now has none after cleaning. Thanks
11-13-2013, 05:52 PM | #3 |
short fiber front wheel bearing grease if you can find it, its heavy enough to stay in the bearing but not so heavy that it gets flung against the outer bearng shell and wont come back to the bearing
11-13-2013, 06:12 PM | #4 |
The modern synthetic rotating bearing greases are very good stuff now days. They last about 50% longer than the old OEM recommendations.
11-14-2013, 06:39 AM | #5 |
