Old 08-27-2020, 06:18 PM   #1
jack wingard
Default Front Brake Shoe Centering
Question about centering front brake shoes. I welded the worn roller track and ground to 1 5/16". Had "Snyders" mount new cast drums on hub, install new bearing races, true the drums and arched the shoes to each drum. The centering tool indicates the top of the shoes has a gap compared to the bottom. How do I bend the roller track upwards to compensate for this. Thanks in advance.
jack wingard is offline   Reply With Quote
Old 08-28-2020, 01:29 AM   #2
Dan Partain
Dan Partain's Avatar
Default Re: Front Brake Shoe Centering
Jack, don't try to bend the tracks for adjustment, that old shade tree mechanic trick has been debunked, there's much info on that in the archives here on FB.
What has worked for me is to weld the tracks and leave them a little higher than 1 5/16". All things considered, I take that 1 5/16" number as an approximate. If you weld and grind them down, but leave some extra height, you can perform your final fit on installation. You can file or grind the remaining amount to achieve the centering that you need. There are good directions regarding centering the shoes here on FB if you do a search.
Here is a track that is welded and roughly filed down. I will file it level before my first attempt to center the shoes.
Dan Partain is offline   Reply With Quote
Old 08-28-2020, 02:17 AM   #3
Kurt in NJ
Kurt in NJ's Avatar
There's roller pins with square head to set in different positions to adjust centering
Old 08-28-2020, 04:00 PM   #4
Werner
Werner's Avatar
Guten Abend Kurt & Co.
That interests me too! Because in the coming winter I have to do the brakes new. Glued soft pads. Because my car is very (!) fading downhill.
Do the setting eccentric pins work really well?
Unfortunately I don't find them at Brattons.
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 08-28-2020, 07:06 PM   #5
The Master Cylinder
The Master Cylinder's Avatar
Flathead Ted makes the shoe centering pins but they are only for the rear. Snyder's has them https://www.snydersantiqueauto.com/P...earchByKeyword
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 08-29-2020, 08:29 AM   #6
Werner
Werner's Avatar
Only rear
I say a big 'Thankyou' for this impotant hint!
Werner
Citroen 11 CV, 1947
Old 08-29-2020, 10:59 AM   #7
wmws
On Flathead Ted's system the fronts center themselves. Works very well.
wmws is offline   Reply With Quote
