Old 01-06-2019, 10:57 PM   #21
Tinker
Tinker's Avatar
Default Re: Please help identify Ford Flathead
Seems high for a chance, but good for you! Pictures of the intake removed and the front oil galley could be more helpful (but really whatever). Good for you.
If you like, HF can be. Or Henry Ford also.... i guess... Not sure if any parts were ever stamped HF.
Old 01-07-2019, 09:13 AM   #22
G32
Alisad;
Please measure the center to center of the main cap bolts. 3 1/4" ? or 3".
Best LB id short of puling the bearing.
Thanks Gene Tulsa
G32 is offline   Reply With Quote
Old 01-07-2019, 09:26 AM   #23
Grassman
Love the water pumps on the top, when did they move them to the Bottom? Learn something new every time I visit Ford Barn.
Grassman is offline   Reply With Quote
Old 01-07-2019, 09:31 AM   #24
rotorwrench
rotorwrench's Avatar
The change to pump in block came in 1937 but they were still 21 stud engines for over a year longer. Ford had used the hot pump method of coolant circulation since the advent of the model A but they finally got wise and started pumping at the cooler end from the radiator in. Circulation was much better and the pumps also served as part of the motor mounts.
Old 01-08-2019, 08:42 AM   #25
Grassman
Thank You for the Info Rotorwrench.
Old 01-08-2019, 11:55 AM   #26
40 Deluxe
Originally Posted by Straightpipes View Post
Toss it
"Toss it"?? Look at post #20. She got 200 bucks for it!!
Old 01-08-2019, 01:56 PM   #27
G32
Originally Posted by Alisad View Post
Thank you guys for your help! Had an offer of a couple hundred so think I’ll let him have the art work! If I post pics of other parts with HF on them may I get some help identifying? HF does stand for Henry Ford correct?
Alisad ;
Did you confirm that the engine was an LB?
That was your question to identify and estimate value.
Thanks
Gene Tulsa
