Old 06-30-2012, 05:13 AM   #1
johnbuckley
johnbuckley's Avatar
Default Tire tube problems
I've had a couple of tubes split where they sit in the well( 19 inch wheels). Is this because the tire is flexing more as it ages or is it poor quality tubes? Any body else had similar problems? What's the solution? What tubes are the best?
johnbuckley is online now   Reply With Quote
Old 06-30-2012, 05:38 AM   #2
peters180a/170b
peters180a/170b's Avatar
Default Re: Tire tube problems
back a few months ago [or later] they were speaking about a BAD BATCH of tubes coming from China.Had the same problem with tubes for our lawn mowers [Scags mowers] .They were all spliting
peters180a/170b is offline   Reply With Quote
Old 06-30-2012, 07:20 AM   #3
1932BB
Has anyone tried motorcycle tubes? They come in various sizes and are usually real rubber rather than Butyl rubber. The reason is, natural rubber will not split like Butyl rubber when it is punctured. A safely issue to be sure.
1932BB is offline   Reply With Quote
Old 06-30-2012, 09:27 AM   #4
johnbuckley
Are 19 inch tubes produced in our size 19x.450-500e for m/cycles? Tried to source some whilst touring Australia in 2008 but all the m/cycle ones were 3.50x 19 ( which I tried but they burst!)
Old 06-30-2012, 07:44 PM   #5
Billaz
I ordered my natural rubber 19" tubes from Berts in Denver. Call them to see if they are still available.
Billaz is offline   Reply With Quote
Old 06-30-2012, 07:49 PM   #6
Billaz
I ordered my natural rubber 19" inner tubes from Berts in Denver. Give them a call to see if they are still available.
Old 06-30-2012, 11:04 PM   #7
Gord. B by the bay
I have used 19 inch tractor tubes and also the 19" motor cycle tubes with no problems with hyway miles Gord. B by the bay
Gord. B by the bay is offline   Reply With Quote
Old 07-01-2012, 12:38 AM   #8
popcorn-guy
popcorn-guy's Avatar
Are you for starters using flaps? My Cretors popcorn truck had all new tubes and tires but they went flat on me and it was because of no flaps. It doesn't take long for a tube to get chaffed through even in a trailer while tied down as the vehicle doesn't sit idle even on a trailer. Mine traveled a lot of miles in my three axle trailer and they were still abraded. Just a thought.
popcorn-guy is offline   Reply With Quote
