Old 03-16-2023, 10:54 PM   #1
poweredbylincoln
Default Screen for coolant on a 32-34 4 cylinder
Does anyone know of a screen I can put in the coolant hose to filter out junk from getting in the radiator on a stock 32-34 4 cylinder? An affordable over the counter part would be great
Thank you
poweredbylincoln is offline   Reply With Quote
Old 03-16-2023, 11:07 PM   #2
tubman
tubman's Avatar
Default Re: Screen for coolant on a 32-34 4 cylinder
A chunk of your wife's pantyhose. Check it often, as it can fill up quickly.
Old 03-16-2023, 11:12 PM   #3
Brian
Brian's Avatar
I just use some fine stainless steel mesh, like what's in a tea strainer, folded up and inserted into the top radiator outlet/inlet. Easily removeable in order to wash out. Prolly more durable than hosiery.
Brian is online now   Reply With Quote
Old 03-17-2023, 02:26 AM   #4
poweredbylincoln
Thank you both I appreciate it
Old 03-17-2023, 09:26 AM   #5
Ray in La Mesa
Check out the Gano filter.
Ray in La Mesa is offline   Reply With Quote
Old 03-17-2023, 09:31 AM   #6
modela4shane
Buy a washing machine drain hose lint mesh screen from Lowes. They are made of stainless steel, they can be fitted in the upper radiator hose and held with a hose clamp.
modela4shane is offline   Reply With Quote
