11-19-2014, 11:04 AM | #1 |
Strange Sparkplug ????
This plug has been knocking around in my display case for years. If I knew its story when I bought it, I SURE CAN'T REMEMBER NOW!!!
The base is identical with a H-10 and it has the same thread size and dimensions. Its constructation would indicate mid 30's or later but the Ford Script seems almost "T" era. Any ideas???? Don |
11-19-2014, 11:22 AM | #2 |
Re: Strange Sparkplug ????
The T plugs used pipe thread, and the As were much bigger threads?...
11-19-2014, 11:48 AM | #3 |
Ford had script plugs made. This might be production line 33-? plug??
11-19-2014, 10:52 PM | #4 |
Thanks guys. I knew that it wasn't T or A or early V8, but what is it?? The bottom base is identical with H10 or H9, but the porcelin is unique.
11-20-2014, 06:36 AM | #5 |
Not a Champion plug, the base is slightly different beside the top. Just a guess maybe foreign Mfg. France, Germany...? Maybe even made by Ford overseas??
11-20-2014, 09:05 AM | #6 |
You might check with Pat MacFarlane in Rochester, NY. He has quite a collection of old spark plugs. He is listed in the EFV8 Roster. Pat |
11-20-2014, 09:19 AM | #7 |
A little OT, and pardon the thread-jacking, but can somebody explain why, with 100 years of US resistance to the metric system, that spark plugs adopted metric threads as the standard so early on?
11-20-2014, 12:08 PM | #8 |
Probably because of Albert Champion...note his last name, THEN note his initials!
11-20-2014, 04:13 PM | #9 |
Don,
you might try the Sparkplug Collectors of America. They seem to know moat about this topic. www.spcoa.net Good Hunting MrPhat40 |
11-20-2014, 05:59 PM | #10 |
The story I heard was that Mr. Champion sold his manufacturing company and then opened a new business, AC spark plug co.
Bruce
Works good Lasts long time Last edited by cmbrucew; 11-20-2014 at 06:00 PM. Reason: cause |
11-20-2014, 06:06 PM | #11 |
Thanks for the lead to the SPCOA. I've sent an inquirey to one of the members.
