Old 09-25-2020, 06:50 PM   #21
Will D
Will D's Avatar
Default Re: 1938 Firestone whitewall tire pressure
Originally Posted by VeryTangled View Post
Hi Everyone. Jacques1960, you didn't ask for this kind of advice, but I'd put tires way up high on your 'to-get' list if you're thinking of driving any distance at all.
Jeff is correct. It isn't recommend to use tires beyond 10yrs old. The rubber is no longer what it once was and has a high potential to fail no matter how they look visually.
Will D is offline   Reply With Quote
Old 09-25-2020, 07:28 PM   #22
tubman
tubman's Avatar
There was an interesting thread on the H.A.M.B. about the age of tires.
The conclusion was that environment and storage conditions are very important factors in service length of tires. In short, tires stored properly (inside, away from UV rays) in cooler climates (I believe Maine qualifies) have a much longer life than tires used in the dry southwest, with the extreme temperatures and copious sunshine.
I think the figure quoted was that over 75% of tire failures occurred in the southwest.
Old 09-26-2020, 03:40 AM   #23
Aarongriffey
It’s dangerous to drive with tires older than six years old.
It’s foolish to drive with tires ten years old.
It’s just stupid, yes stupid to drive with it’s tires 15 years old.
Ask Ford and Firestone.
When I worked in service stations in the fifties we put 28 lbs. in passenger car tires.
32 for rear tires on loaded station wagons and half ton pickups.
Most car factories list the tire pressure on the low side.
Aarongriffey is offline   Reply With Quote
Old 09-26-2020, 07:05 AM   #24
Jacques1960
Jacques1960's Avatar
Added to the list 👍🏻
Jacques1960 is offline   Reply With Quote
Old 09-26-2020, 07:08 AM   #25
Jacques1960
Age aside, the tires have less than 500 miles on them. Prior owner lived in Ontario CA and kept car garaged and on jack stands “off season”.
Will plan on replacing next year.
