08-10-2020, 08:21 PM | #1 |
Isky or Potvin
Did the late Jazzy Nelson use a Isky or Potvin cam in his FH powered car. I do know it was pretty fast for it time. The Bean bandits used to respect it.
08-10-2020, 08:27 PM | #2 |
Re: Isky or Potvin
505A Isky.
08-10-2020, 08:34 PM | #3 |
Re: Isky or Potvin
Does the 505 represent the lift as the 404 did?
08-10-2020, 09:00 PM | #4 |
Re: Isky or Potvin
Approximately. It has .515 lift.
08-10-2020, 09:11 PM | #5 |
Re: Isky or Potvin
That's amazing. I never heard of that cam before. I wonder if Tom Beaty(sp) was aware of it or maybe it was not a good cam for the salt flats.
08-10-2020, 09:35 PM | #6 | |
Re: Isky or Potvin
I talked to Tom many times at Bonneville but we never discussed cams. I am sure he was aware of it. It would work very well at Bonneville. |
08-11-2020, 09:03 AM | #7 |
Re: Isky or Potvin
Have you ever tried to grind a 505A or would it be impossible to do without a core to start with?
08-11-2020, 02:28 PM | #8 |
Re: Isky or Potvin
08-12-2020, 08:07 AM | #9 |
Re: Isky or Potvin
Pete, what kind of springs do you use for that? Is this a roller cam?
08-12-2020, 01:34 PM | #10 |
Re: Isky or Potvin
08-12-2020, 02:40 PM | #11 |
Re: Isky or Potvin
Rana 404 once, wazent happy with it!! 400 jr ran better, but that was probably my fault.
08-22-2020, 01:28 PM | #12 |
Re: Isky or Potvin
505 lift. I take it you need a billet cam with no cam bearings in the block? Or you modify the block for that much lift?
08-22-2020, 03:25 PM | #13 |
Re: Isky or Potvin
08-22-2020, 05:38 PM | #14 |
Re: Isky or Potvin
And here are some pictures of the 505A that Pete is talking about - with some side-by-side shots against the 404A.
I have yet to run the cam, need to build a very "special" engine for it. 505-A-lowres.jpg 505-404-Fronts-lowres.jpg 505-404-TopBottom-lowres.jpg And Jazzy Nelson's Coupe . . . probably the fastest drag coupe that ever ran a flathead. Jazzy ran the 404A quite a bit, but "wanted something bigger - and a secret grind" - that is when Ed made the 505 for him. JazzyNelsonFiatCoupe.jpg |
Thread Tools | |
Display Modes | |
