Old 06-05-2020, 10:52 PM   #1
JCHarvey
Default Whistling sound when clutch is not engaged
I have a whistling sound when the clutch is not engaged, I think it might be the throwout bearing but it's only 1000 miles since it was installed in a long block rebuild.
The sound is fairly high pitched and sounds like a whistle.
Any thoughts on what this is?
JCHarvey is offline   Reply With Quote
Old 06-06-2020, 05:09 AM   #2
ronn
Default Re: Whistling sound when clutch is not engaged
show tunes son..............youre car likes show tunes!
Old 06-06-2020, 06:25 AM   #3
Patrick L.
Patrick L.'s Avatar
If you have proper [ 1.0-1.5"] freeplay then the T/O bearing should not be touching the fingers. That means the bearing is not spinning, therefore no noise. If you take out the freeplay so the bearing is contacting the fingers and it makes noise then the bearing is bad. If the noise you're hearing with foot off the clutch pedal is more of a 'whirring' noise then thats normal.
Old 06-06-2020, 06:25 AM   #4
1crosscut
1crosscut's Avatar
Pull the inspection cover off and take a look to see if the throw out bearing is turning.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 06-06-2020, 07:32 AM   #5
1931 flamingo
1931 flamingo's Avatar
Vacuum leak??
Paul in CT
Old 06-06-2020, 07:34 AM   #6
Bob Bidonde
Bob Bidonde's Avatar
Also inspect the pulley on the front of the crankshaft because it may be rubbing against the frame's front crossmember.
Bob Bidonde
Old 06-06-2020, 07:48 AM   #7
nick c
Might be the pilot bearing.
nick c is offline   Reply With Quote
Old 06-06-2020, 11:16 AM   #8
katy
katy's Avatar
W/the clutch pedal released the pilot bearing will be spinning as a whole unit.
Old 06-06-2020, 11:18 AM   #9
katy
katy's Avatar
Check the transmission to be sure it has enough oil in it.
Old 06-06-2020, 11:21 AM   #10
abachman3
abachman3's Avatar
I too, would suspect the throwout bearing I had a similar occurrence a few years back when I purchased my Tudor. The motor only had 700 miles on it. I replaced the throwout bearing and all is well after 12,000 miles.
abachman3 is offline   Reply With Quote
Old 06-06-2020, 05:05 PM   #11
old31
Nut Bob, wouldn't that be rubbing regardless if the clutch is in or out?
Old 06-06-2020, 05:10 PM   #12
old31
6 or 7 years a go I had the trans out (not model a) it had about 5k miles.
So I replaced the t bearing because I am so smart. Sure enough the factory tbearing was bad, out comes everything again. Not a good garage day. Worst part , it was not my fault.
Old 06-07-2020, 11:22 AM   #13
JCHarvey
Thanks, all for the advice on how to troubleshoot.
I pulled the inspection cover off and found the throwout bearing does not spin when the clutch isn't engaged. Also the whistling noise is loudest when the the clutch in not engaged but is still present with or without the clutch in.
The more I run it and listen I think the sound is either coming from the fan belt, fan or alternator pully. The fan belt was rather loose (maybe 1 1/2" play), so I tightened it slightly and that didn't seem to help.
I checked pulley and it's not rubbing on the crossmember and the fan is not loose and there's no play.
After seeming to narrow the sound as coming from the front of the car it seems like it might be the fan belt slipping or if drying can it make a whistling/squeaking
sound?
I have a video recording but it doesn't appear I can upload even a few seconds without exceeding the allowed file size.
Old 06-07-2020, 11:52 AM   #14
Marshall V. Daut
Check your "Private Messages" in the top right corner of this web page.
Marshall
Old 06-07-2020, 03:36 PM   #15
1crosscut
1crosscut's Avatar
Spray a little bit of water on the fan belt as it is running to see if the sound changes.
Or disconnect the fan belt and see if the noise goes away.
Old 06-07-2020, 03:46 PM   #16
Fred K OR
sound?
Take the fan belt loose from generator and fan and see if it still has noise. If it doesn't change, then it is not in this area. (but don't forget to put it back on)
Fred K OR is offline   Reply With Quote
Old 06-07-2020, 06:54 PM   #17
Synchro909
Synchro909's Avatar
If the car has rubber engine mounts, the motor can move forward a bit when the clutch is pressed. On one of my cars, I have a squeak in the front engine mount which disappears when I press the clutch.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 06-09-2020, 05:54 PM   #18
JCHarvey
Problem Solved! See solution at end of post.
Thanks for the advice on the troubleshooting. Here's what I did.
I didn't know if ronn meant it likes show tunes or doesn't so I changed the radio dial from Pink Floyd to Show Tunes. No change.
I pulled the inspection cover and found the TO bearing was not rotating with the clutch out so that was good and the sound just didn't seem like it was coming from that area.
Pulled the fan belt and determined the noise still present.
Tightened bolts on exhaust manifold and two bolts on carb to try and eliminate vacuum leak if there was one. They weren't loose but tightened up a little. Still had the noise.
Checked the fan belt pulley from the crankshaft and seemed to have clearance. Finally, sprayed a little WD-40 on the fan pulley and BINGO the noise ceased. So it was the fan belt pulley at the crankshaft rubbing. I loosened the castle nut about 1 turn and no more noise. I think the reason the noise was loudest with the clutch not engaged must have been engaging the clutch moved the engine just enough for the pulley to clear the cross member but also noticed as the engine ran longer the noise was present with and without the clutch engaged. Must have barely been touching so didn't take much movement for the sound to go away.
Thanks again for the help. I'm getting more confidence that it is actually possible to troubleshoot these things with a little help.
