09-28-2018, 06:43 PM | #1 |
Isky 88 cam and double spring question
A little background
I'm trying to help someone get there motor (8ba) running properly. It's a fresh rebuild from a machine shop that is not familiar with flatheads. What I found was an isky 88 cam with stock valves,isky 4005 springs & 87f spring retainers with no shims installed. I can lift a valve up 1/4" off the seat with 2 fingers. Isky calls for an installed spring height of 1.687" with 115 lbs of seat pressure. That seems like I'm going to need a whole lot of shims and an excessive amount of seat pressure. I've always used the 185g springs with never more than 90lbs of seat pressure on a lot bigger cam. So should I go by iskys recommendations and use the 4005 springs? Or should I use 185g springs? Or ? Thanks in advance |
09-28-2018, 08:51 PM | #2 |
Re: Isky 88 cam and double spring question
Deleted by ron
09-28-2018, 08:53 PM | #3 |
The isky 88 cam is a very mild cam and only 50 Lbs is necessary for a street engine. Over the years I've sued several of them. Not a very good choice.stock springs with a .060" shim
09-28-2018, 09:05 PM | #4 |
I'm with Ron.
09-29-2018, 09:52 AM | #5 |
Agree with above
09-30-2018, 07:17 AM | #6 |
09-30-2018, 10:52 AM | #7 |
That comes from picking the wrong builder.
