04-14-2016, 05:30 AM | #1 |
Crack in block
Looking at the 8ba I picked up, see a crack from valve seat to cyl. Is this a common thing ?? What to do with it ? Thanks.
04-14-2016, 05:45 AM | #2 |
Re: Crack in block
Some cracks are okay, and sorta expected/acceptable, but unfortunately, that's not one of them. I'm certainly no expert on this subject, but it could probably be pinned at the ends of the crack, and welded. Just adds more $$'s to the build. Can you post a picture?
04-14-2016, 06:24 AM | #3 |
Re: Crack in block
Would also require a sleeve on that cylinder.
Respecting and Resurrecting Ford Model A's. |
04-14-2016, 09:16 AM | #4 |
Re: Crack in block
Not too long ago, you would have been advised to scrap that block and find another, as there were plenty of good blocks out there. Today, this is not quite the case; I've read stories of guys looking at a dozen or more blocks to find one that is not cracked. It appears that the supply of perfect blocks is dwindling.
In my own case, my 8BA block in my 51 F1 had the same crack, from cylinder wall to valve opening. The machine shop that rebuilt the engine was able to pin it, then sleeve the cylinder. This block did not have hardened valve seats, so instead of just installing a valve seat at the valve with the crack, I had them install at all valves. Modern gas burns hotter, and I read that valve seat erosion is likely without the hardened valve seats. The shop baked and blasted the block and Magnafluxed it before attempting to repair the crack. This was the only crack, so they fixed it; after sleeving the cylinder and installing the valve seat, they pressure tested the block before going any further. The block passed, so I had them complete the rebuild. The pinning and sleeving added $572.84 in labor and materials to the cost of the rebuild. The Magnfluxing, pressure testing, and valve seats would have been done with or without the crack, so they were not an additional cost. Yes, it would have been nice to have or been able to find a perfect block, but I am happy with the result that I got using this block. Of course, if you are planning to make this a faster, higher HP engine, then I would recommend that you do find a perfect block. Mine is all stock, so the repaired crack will not be an issue for me. |
04-14-2016, 09:31 AM | #5 |
Re: Crack in block
Baking and blasting, I think it is more akin to a tumbler in steel shot, is the best way to clean a block. You will need to put a preservative on it as the heat burns every last molecule of oil out of the cast iron. So I'm told.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
04-14-2016, 09:51 AM | #6 |
Re: Crack in block
R Last edited by Ronnie; 04-14-2016 at 09:57 AM. |
04-14-2016, 10:11 AM | #7 | |
Re: Crack in block
04-14-2016, 10:14 AM | #8 |
Re: Crack in block
When I took my first flathead to the machine shop to be tested, they found a crack. I asked about repairing it and was given the best advice on what to do.
To quote the machinist..... " look at how much you are investing into rebuilding this engine, Starting off with a cracked block is not a wise decision. Find a good block to start with. You will be happier knowing you did." It was not about if the crack could be repaired or not, and I'm sure the comment will raise great debate. But in the end I am sure we would all like to start out with a good un cracked block. I have since purchased tools and equipment for pinning cracked blocks and experiment on two of them. The one block the crack ran well down into the bowl area of the exhaust. The casting was so thin that I was barely grabbing 3 threads on the plug. I quickly decided that block was best set aside. The other block had a small crack that stopped at the seat. it was pretty easily repaired and I would not hesitate to use it. I also dare not start the welding VS pinning debate...LOL |
04-14-2016, 10:39 AM | #9 |
Re: Crack in block
My block is at the machine shop right now getting a sleeve. The crack was from a water jacket to the cylinder. Price from the machine shop was 140.00.
04-14-2016, 10:44 AM | #10 | |
Re: Crack in block
R |
04-14-2016, 10:51 AM | #11 |
Re: Crack in block
Did you get it done in MA?
04-14-2016, 10:54 AM | #12 | |
Re: Crack in block
04-14-2016, 10:56 AM | #13 |
Re: Crack in block
04-14-2016, 10:58 AM | #14 |
Re: Crack in block
If Frank Casey is still around, he pinned several of mine and we ran right on the pins, no need to install a sleve. AS far as I know, they're still running.
04-14-2016, 11:15 AM | #15 |
Re: Crack in block
04-14-2016, 11:40 AM | #16 |
Re: Crack in block
I think you have me confuse with another poster...Never said you got dumped.
04-14-2016, 11:43 AM | #17 |
Re: Crack in block
04-14-2016, 12:19 PM | #18 |
Re: Crack in block
04-14-2016, 06:11 PM | #19 |
Re: Crack in block
we have a shop here that specalise in repairing cracks in cyinderheads (tractor- semis desiel) last time I heard they would not touch a flathead-- best to find a good block here in Iowa you can find them-- I have 3 that have been hot tanked + magged good
04-14-2016, 06:45 PM | #20 | |
Re: Crack in block
I had Frank pin a block for me about 8 years ago. Excellent craftsman. You sort of hint he is not doing it any more?? Thanks John |
