09-09-2014, 07:06 AM | #1 |
fuel pump removal
A friend wants to remove his mechanical fuel pump and use an electric pump. The engine is a 59AB.
My question is: Does anything need to be done to plug the fuel pump pushrod opening in the block? I know on a 8BA the bushing has a oiling hole in it. Is the 59AB the same? |
09-09-2014, 07:26 AM | #2 |
Re: fuel pump removal
Type "Fuel Pump Rod Bushing" in the search box and a lot of info. will appear.
09-09-2014, 08:10 AM | #3 |
The 59AB does not have the oil hole.
09-09-2014, 10:02 AM | #4 |
It is true there should not be any hole in the 59A fuel pump rod bushing. However, there can be allot of oil thrown off the eccentric and up toward the breather. I always put a tapered plug in the bushing to prevent that from becoming a problem. However, if all the stock baffle system is in place I doubt that any problem would exist.
09-09-2014, 10:21 AM | #5 |
If he is your "friend", advise him to put a good mechanical pump on. Then if he wants a "backup" he can install an electric pump also. No back up if the electric fails and without a regulator it might have too much pressure.
JMhumbleO John |
09-09-2014, 10:21 AM | #6 |
09-09-2014, 11:11 AM | #7 |
I'm with John. I had an electric pump on mine for years and had to replace it several times. I decided to take a good look at the problem, and found that most stock pumps can develop a slight leak at the mating surface of the sediment bowl. I ended up facing the sediment bowl on my surface plate using w/d sand paper and replacing the neoprene gasket with a cork one (why this helps is a mystery to me). This solved all of my problems, and I ended up completely removing the electric pump about a year later and never looked back.
09-09-2014, 11:14 AM | #8 |
Electric pumps can be a problem, I have had no end of problems with some of them. But, almost all modern cars use electric pumps, so I think the real issue is the quality of the pumps and the quality of the installation. Some times you almost have to use the electrics.
09-09-2014, 01:25 PM | #9 |
09-09-2014, 01:27 PM | #10 |
But most modern elect pumps are in the gas tank so they stay cool and not over heat.
09-09-2014, 01:54 PM | #11 |
Curiously most older cars with electric pumps had them mounted almost anywhere EXCEPT in the fuel tank. They soldiered on for decades ?
09-09-2014, 10:19 PM | #12 |
My '47 has had an electric pump as a back-up for about 15 years. Have not yet used or needed it full-time. With a toggle switch I run the electric pump for about five to ten seconds before starting the engine. I maybe lucky so-far but it starts every time hot or cold weather ( unless I forget to pull out the choke ).
09-09-2014, 11:34 PM | #13 |
I've run the same mechanical pump for almost ten years... And, it was used when I got it.
A 7/16" valve guide will fit, light press, in place of the fuel pump bushing. I have done that, threaded for a 5/16" 18 set screw. -Before I decided to run the mechanical pump. I pulled out my set screw and used the threads I put in the guide to put a bolt in to pull it out... What I'm saying is don't cut pipe threads in the block, that's not reversible. Karl |
