Old 07-28-2014, 06:51 PM   #1
Heard
Heard's Avatar
Default Man, I got dirty just thinking about this engine.
[IMG][/IMG]
Waiting on parts for my coupe, I thought I'd go ahead and start digging into this 8ba to see if the block is any good. It is WAY greasy which I think is better than being WAY rusty.
It isn't frozen up but that one head doesn't look so good does it?
[IMG][/IMG]
I can't see any obvious cracks but that doesn't mean much coming from me. We'll see....
[IMG][/IMG]
I don't know who came up with the idea of welding a washer on the broken studs and then welding a nut onto the washer, but that worked great! I had 10 broken studs on this block. 3 or 4 were broken before I got it and then I broke some. I'm a slow learner....but all of the studs are out now.
Do I look like I have a plan B?
Heard is offline   Reply With Quote
Old 07-28-2014, 07:02 PM   #2
ford38v8
ford38v8's Avatar
Default Re: Man, I got dirty just thinking about this engine.
I don't know, but I found it at fordgarage.com a few years back.
http://www.fordgarage.com/pages/studremoval.htm
Alan
Old 07-28-2014, 07:07 PM   #3
Barry-ct
Barry-ct's Avatar
I've seen worse, but that one is definitely DIRTY!
Barry
50 F-1
Barry-ct is offline   Reply With Quote
Old 07-28-2014, 07:33 PM   #4
texas webb
Alan,ain't fordgarage a neat site.I've found lots of good&useful info there.
Webb.
texas webb is offline   Reply With Quote
Old 07-28-2014, 07:54 PM   #5
Binx
Looks like maybe a '49-'50 car motor with the early valve springs and retainers. Head studs are interesting too but not unheard of. Solid lifters hint that it may have never been rebuilt unless Walt got hold of it back in the day.
Lonnie
Binx is offline   Reply With Quote
Old 07-28-2014, 08:10 PM   #6
Merc Cruzer
Merc Cruzer's Avatar
Power washer
Merc Cruzer is offline   Reply With Quote
Old 07-28-2014, 08:24 PM   #7
40cpe
40cpe's Avatar
check the pan rail and inner water jackets before putting too much labor into it.
40cpe is offline   Reply With Quote
Old 07-28-2014, 10:50 PM   #8
ford38v8
ford38v8's Avatar
Webb.
Yeah, but not too much beyond the Model A's.
Alan
Old 07-28-2014, 11:19 PM   #9
Brian
Brian's Avatar
Heard, I hope it's [the block] worth it. Those dirty greasy flatheads have a smell, don't they? Gets right into the pores of your skin, under your nails, in ya hair....
Joe Bloggs public, in their modern shitboxes, can never perceive what we willingly go through. Have fun.
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 07-28-2014, 11:39 PM   #10
lecktrix
lecktrix's Avatar
Thats a Pennzoil killed block... Lots of people dedicated everything they had to one motor oil, and when you open up a true Pennzoil users motor, this is what it looks like. It was a wax based motor oil, and as you can see, this is what it did. Look it up further on any site.. Pennz helped motors, but totally gunked them up.... Sure in the later years it was different and detergent... but look at early posts about original engines destroyed by gunk, and took three days in the hot tank to clean
lecktrix is offline   Reply With Quote
Old 07-28-2014, 11:48 PM   #11
lecktrix
lecktrix's Avatar
I just recieved four 1941 engines from a local mine that was a religious pennzoil user... Anything inside that I touched stained my skin black... I had my grease monkey use my craftsman tools to take it apart... yes im a prick when it comes to my Snap On tools, since im the geek that likes the orange and green tools they offer... We are still cleaning up from the teardowns... nasty pennzoil waxy, black crap
Old 07-29-2014, 05:33 AM   #12
2935ford
2935ford's Avatar
Isn't this the way they all are?
Here's my Canadian 59A block.
2935ford is offline   Reply With Quote
Old 07-29-2014, 06:41 AM   #13
Heard
Heard's Avatar
Have fun.
Brian, you are right on...the smell....I don't even know how to describe it. It's really strong.
Lonnie - I don't know if this one was ever rebuilt or not. It does have the standard bore which is good.
Old 07-29-2014, 07:15 AM   #14
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Lonnie
The first 8BA engines in the 48 trucks had studs instead of cap screws, they also did not have a bushing in fuel pump push rod hole. They also had a 1/8 pipe plug in the back where they bored a small hole in to the main oil line to piss oil onto the push rod. Up here when we stripped a gunked up engine like that we always said they used Quaker State oil. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 07-29-2014, 07:16 AM   #15
Cecil/WV
Cecil/WV's Avatar
I don't think Pennzoil had a monopoly on gunk in an engine. It has more to do with non detergent and lack of maintenance.
Cecil/WV is offline   Reply With Quote
Old 07-29-2014, 08:48 AM   #16
JSeery
JSeery's Avatar
I ran Pennzoil in the 1960s and early 70s because of all the racer hype. Had an uncle in the oil business that told me how bad it was, he claimed because of high sulfur content. It had to do with the type of oil that was used to manufacture it. When we started tearing down some of those engines they were a mess. I have never seen any other oil create the mess Pennzoil did, it was really bad, almost like a thick tar coating inside the engines. Made a believer out of me, stopped using Pennzoil and the problem went a way. All older engines are a bit messy inside when you tear them down but a Pennzoil engine is in a league of it own!
Old 07-29-2014, 10:10 AM   #17
Russ/40
Russ/40's Avatar
Ill take the greasy one over the rusty one any day!
Russ/40 is offline   Reply With Quote
Old 07-29-2014, 11:45 AM   #18
Heard
Heard's Avatar
I mis-stated that earlier. I said it had 10 broken 'studs'. They were actually head bolts or what I think you are (properly) calling cap screws. The welded washer/nut trick worked great, though.
Old 07-29-2014, 11:52 AM   #19
JSeery
JSeery's Avatar
My current engine came out of a 48 Truck and it's a 59a, any idea when they switched to the later model engine? On the oil issue, don't think it had so much to do with Pennzoil as it did with the oil used to manufacture it. It was the Pennsylvania oil that was the problem. I was told it was a high sulfur oil and that caused the issue.
Old 07-29-2014, 12:07 PM   #20
Tim Ayers
Think of as rust preventer. It sure makes a mess, but no way is rust getting to those surfaces.
