05-28-2014, 08:15 PM | #1 |
Would you try to save this?
This cylinder has a lot of pitting around the intake valve over to the cylinder. I can put a new seat in it and deck the block slightly but I am worried about this causing detonation or being a problem.
05-28-2014, 08:20 PM | #2 |
Re: Would you try to save this?
I don't think I would attempt the recovery of that block but there may be guys that could.
05-28-2014, 08:31 PM | #3 |
If that is the worst of it why not use it?? I have removed lots of pistons like that and then had seats replaced.
05-28-2014, 08:41 PM | #4 |
I'd give it a try. I've saved some pretty bad blocks. Jave it back cleaned and pressure tested. Then bore it to see how bad the cyls are and install over size valves. Might make a real strong engine/ I've also put in oversize valves in stock engines just to save them
05-28-2014, 10:02 PM | #5 |
I would but I don't know what I am doing....
Short URL: http://smu.gs/14g7eDW |
05-29-2014, 07:21 AM | #6 |
05-29-2014, 08:02 AM | #7 |
I had the same problem on my 8BA, bored it at 3 5/16" and relieved the block around the valve to piston area. Made a mask and used my router with an end mill. Runs great. Also polished the ports. Zeke
Only problem with retirement is never a day off |
05-29-2014, 08:04 AM | #8 |
If too bad to save, sleeve that bore and go ahead with the rest. If it checks out otherwise, use it brother!
05-29-2014, 09:34 AM | #9 |
After you blast the rust off you may be pleasantly surprised. If not, it's a great candidate for relieving. I like Zeke's template.
05-29-2014, 09:42 AM | #10 |
05-29-2014, 07:04 PM | #11 |
I would try to save it just to see if i could. Might make a strong runner
05-29-2014, 07:08 PM | #12 |
Only as a last resort. There are others to be had.
I wouldn't throw it away, at least until a rainy day and had nothing else to do but play with it. But I'm one of those guys that's been hoarding flatheads. Last edited by Russ/40; 05-29-2014 at 07:16 PM. |
05-29-2014, 07:17 PM | #13 |
Any of these old FH blocks are worth trying to save. If you don't care to spend the $$'s trying to save it, at least store it in case someone else is willing to spend the $$'s some time in the future.
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 05-29-2014 at 11:27 PM. |
05-30-2014, 07:32 AM | #14 |
I agree completely. I thing we are getting to point where it is going be necessary to start saving what would have been boat anchors a few years ago. I have one with a small pan rail Crack that I don't need now but I'm saving because I know down the road It will be worth fixing. I only have 4 flatheads right now but I will take anything I can grab now because it will only get harder to find one in the future.
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. " |
05-30-2014, 07:42 AM | #15 |
shoot I'd fix that. Or, you can wait on the Chinese block coming to a Speedway near you.
05-30-2014, 07:47 AM | #16 |
Zeke, I like that template, what did you make it out of? Walt
05-30-2014, 11:27 AM | #17 |
03-07-2018, 09:24 PM | #18 |
Just following up on my initial post, didn't realize it had been almost 4 years since I tore this engine down! I did decide to save this block and just got it back from the machine shop today. I ended up putting 1.550" valves in it and relieving the block and it all cleaned up pretty good.
03-07-2018, 09:31 PM | #19 |
If that's the same cylinder, you done good!
03-07-2018, 09:34 PM | #20 |
I also had to tig weld with Ni rod some of the intake port so there would be enough material there to seal. Also relieved and drilled the lifter bores. This engine will be getting a 4.250" stroke SCAT crank and rods with 2.000" journals and Mahle forged 3 5/16" pistons. Also, a 3-71 blower on top with 2 Holley 94 carbs.
