Old 08-25-2020, 04:27 PM   #1
Ol' Ron
Ol' Ron's Avatar
Default Power Nation Flathead
I just watched an episode of Power nation. The engine in question was a 302 ci flathead. 65CC heads, block was relieved, and 3 94 carbs were installed, No Cam specs were mentioned Power was just shy of 160HP torque 267 . No RPM were called out. Kinda makes you wonder where all these 200hp flatheads come from
Old 08-25-2020, 04:45 PM   #2
Angledrive
Angledrive's Avatar
Default Re: Power Nation Flathead
Dreams?
Angledrive is offline   Reply With Quote
Old 08-25-2020, 04:57 PM   #3
frnkeore
frnkeore's Avatar
Did they give the total chamber volume, or, just the heads?
Frank
'35 Ford Model 51
'48 Ford F3
'54 Ford Tudor Mainline
frnkeore is offline   Reply With Quote
Old 08-25-2020, 05:13 PM   #4
Angledrive
Angledrive's Avatar
That was just the heads. Block was relieved about .090.
Old 08-25-2020, 06:12 PM   #5
F-ONE
F-ONE's Avatar
They're very small horses.
These are the same horses that live in 500HP 350s and 450HP SBF 302s.
F-ONE is offline   Reply With Quote
Old 08-25-2020, 08:50 PM   #6
V8COOPMAN
V8COOPMAN's Avatar
Now that Sir, is FUNNY! Probably, more truth to that statement than one can imagine. Cute li'l horsey, for sure! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 08-25-2020, 09:36 PM   #7
Ol' Ron
Ol' Ron's Avatar
Love it!!
Old 08-26-2020, 12:37 PM   #8
mfirth
Makes me think of a V8-60, they are cute too.........
mfirth is offline   Reply With Quote
Old 08-26-2020, 03:23 PM   #9
Pete
Pete's Avatar
I saw that program also. For what they did to the engine, which was almost nothing, the dyno readings were very honest.
Old 08-26-2020, 04:45 PM   #10
51 MERC-CT
51 MERC-CT's Avatar
And then?
Old 08-26-2020, 05:52 PM   #11
Ol' Ron
Ol' Ron's Avatar
I Wonder what cam they used? When JWL modified the stock engine, it produced very little HP reguardless of all the add on, untill a mile cam was installed and that helped allot. Most of the 276 Street engines i build only produced 130/140 Hp @ 42/4800, But this was more than double the original.
Old 12-23-2020, 08:16 PM   #12
23sbob
you just gotta love this engine
23sbob is offline   Reply With Quote
Old 12-23-2020, 10:12 PM   #13
Newc
Newc's Avatar
This explains those fast GMC/Chevs. Bought [2] 261 blocks today. Newc
Old 12-23-2020, 11:19 PM   #14
Ol' Ron
Ol' Ron's Avatar
Been watching allot of LS and LT builds and the new aftermarket alum heads for the old engines. It seems that the biggest modification is the elinination of the bowl under the valve and blending it into the original port. JWL did something like that. Some thought should be given to this.
Gramps
Old 12-23-2020, 11:34 PM   #15
38 coupe
38 coupe's Avatar
Did JWL ever publish the final power figure of his engine? I'm curious how it compared to the stock and mildly modified 8BA described in his book. I'm not curious about a final number as a true horsepower figure due to differences in dynos as described in his book.
Old 12-23-2020, 11:59 PM   #16
Lanny
Lanny's Avatar
Rick Schnell of MN. built the worlds quickest single engine flathead dragster
a few years ago. Has a Very-Very highly modified Ford flathead, 900 hp.
Here's a link to a short video below.
https://www.youtube.com/watch?v=2YHs0CG8MA8
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
Lanny is offline   Reply With Quote
Old 12-24-2020, 02:17 AM   #17
Tinker
Tinker's Avatar
It's TV.
Oh man. Now I want one of these.
[/QUOTE]
Old 12-24-2020, 02:24 AM   #18
Tinker
Tinker's Avatar
you don't need a 1000 ponies to go fast.
https://www.youtube.com/watch?v=uI6NmRjMsPk
Old 12-24-2020, 04:40 AM   #19
V8COOPMAN
V8COOPMAN's Avatar
[/QUOTE]
Problem is that they don't ride very well. Your feet tend to drag continuously and it slows the horsy down a lot! DD
T5 W/TORQUE TUBE
Old 12-24-2020, 04:47 AM   #20
Tinker
Tinker's Avatar
I have a pet monkey, a tin can, and I plan to travel the land in a van. So I'm good.
