Old 05-23-2020, 05:00 PM   #1
miff
Default Canít keep it running no power
Canít keep it running no power Some history itís a 1931 Model A Model speedster standard engine high compression head mechanical spark advance duel updraft model B carburetors fuel tank is in the rear has a fuel pump 12 V system when you go to start it you have to
Over choke it to get it to run and to idle you have to screw the Gav out 2 1/2 to 3 times and run with a half choke will settle down (stop choking it )and you accelerate and no power when I put it together it ran fine The beginning of last summer it was running fine then Near the end of the summer it started acting up during the winter I reset the timing I went through all the things that I could think that might be wrong now took it out today and weíre back to square one Any ideas
miff is offline   Reply With Quote
Old 05-23-2020, 06:20 PM   #2
Roxo
Roxo's Avatar
Default Re: Canít keep it running no power
It could be sucking air somewhere. I would first check your intake manifold gaskets, Carb to manifold gaskets. I have this issue with two stroke engines a lot. You have to keep them choked to run.
Roxo is offline   Reply With Quote
Old 05-23-2020, 06:26 PM   #3
miff
thanks will try that tomorrow
Old 05-24-2020, 03:32 PM   #4
SteveB31
SteveB31's Avatar
You have a fuel pump problem or fuel blockage, or carb plugged up.
On a side note, once a car is timed, it never needs re timed. Never have figured out why folks always want to retime their Model A anytime it quits. Last time I timed mine was 22,000 miles ago.
Drain your gas, check fuel pressure, clean carbs and you should be good to go.
SteveB31 is offline   Reply With Quote
Old 05-24-2020, 03:43 PM   #5
shew01
shew01's Avatar
Iíve wondered that myself. Could it be because other ďoldĒ cars from the 60ís could ďjump timeĒ due to a cantankerous distributor bolt that could loosen on its own?
Old 05-24-2020, 05:29 PM   #6
Big hammer
50 years ago I was told if you can't put your car in high gear and walk beside the car you don't have it timed right. I've given up on that many years ago, I've quit missing around with timing, set it and forget it.
get a bigger hammer tap done
Old 05-25-2020, 04:51 AM   #7
Wick
Wick's Avatar
Intake gasket leak. Also try a gravity feed test tank. If the tank fixes it then your fuel system need attention. The 12v pump should be at the tank.
Wick is offline   Reply With Quote
