03-07-2018, 10:10 PM | #21 |
Re: Would you try to save this?
Now THAT'S "a silk purse out of a sow's ear"!
03-07-2018, 10:24 PM | #22 |
Very good work! You earned this one brother.
03-07-2018, 10:44 PM | #23 |
Great work!
03-07-2018, 11:58 PM | #24 |
Ya done good......impressive....!!!
Whether you think that you can,or that you can't,you are usually right....H.Ford |
03-08-2018, 12:40 AM | #25 |
Could you fill in a few blanks. What size seats? How much did you take off the decks. It looks very nice.
03-08-2018, 08:39 AM | #26 |
03-08-2018, 09:43 AM | #27 |
Did you bore it to 5/16 yet? I see it was an original 1/16 block.
03-08-2018, 09:56 AM | #28 |
I would check the cylinder walls before going much over 3 3/16 on a 3 1/16 block...at 3 3/16 +040 you usually start getting real thin walls on good blocks...
03-08-2018, 02:58 PM | #29 | |
Look at the picture of the block its a 59A so I would imagine 3-3/16 bore stock not 3-1/16.
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
03-08-2018, 03:17 PM | #30 |
Ronnie, he stated in a post above that its a 59 block but its the odd "replacement" block with a 3 1/16 bore.
I have one of these stupid blocks, and I'm very surprised it went 3 5/16 without windows in the cylinder bore. Martin. |
03-08-2018, 05:41 PM | #31 | |
Never had my hands in one of those so its true you learn something new every day. Certainly would be a good idea to get the walls sonic tested for thickness then.
