04-18-2021, 01:24 PM | #1 |
Stuck column drop 34 sedan
The key won’t turn and my steering wheel is locked. What now? It worked yesterday. 34 DeLuxe Fordoor.
Tim Carlig |
04-18-2021, 02:35 PM | #2 |
Re: Stuck column drop 34 sedan
Wigle the key , lift it a bit . My 34 is the same , worn original key and lock . I have to lift the key a bit while turning . Dont force it .
04-18-2021, 03:55 PM | #3 |
If you jack up the front axle and have both front wheels off the ground, that may relief some pressure on the steering column shaft and enable you to turn the key along with wiggling it in different position as noted above.
04-18-2021, 11:38 PM | #4 |
Got it unlocked. Took the lever off and put a longer 10/32 screw in so I could get a grip on the screw with a vice grips. Then as I pulled on the grips I wiggled the key to the LEFT and it unlocked. I previously was trying to turn the key to the right.....Duh!
Tim Carlig |
04-20-2021, 04:19 PM | #5 |
Why would you lock it? Click the lever to off and turn off the battery safety switch or unhook the battery terminal. I never lock any of them for that reason and always unhook a terminal. After all- locks are for honest people only.
04-20-2021, 06:15 PM | #6 |
you can remove it to change the lock cylinder |
04-21-2021, 11:53 AM | #7 |
GSCOV, I locked it to get the key out for comparison with another key. Normally I never would lock it. What would be defective, the piece that slides in and out? What’s the proper name for that piece? Thanks
Tim Carlig |
04-21-2021, 01:01 PM | #8 |
Taking it all apart and cleaning would be a big help, but mainly the lock cylinder and key usually gets worn and wont accept the key without some wigglin
04-21-2021, 01:05 PM | #9 |
The lock has a code on the side. A new key can be made from the code and sent to you without sending the lock away.
