Old 01-09-2021, 04:19 PM   #1
46woodie
Default 46 light switch
Ok, having problem keeping light switch knob from popping out of switch assembly. I insert, then give swift push inward. Latches but not securely. Pulls out of switch body when going to headlight position. What is correct way of inserting this into switch body???
46woodie is offline   Reply With Quote
Old 01-09-2021, 04:26 PM   #2
19Fordy
19Fordy's Avatar
Default Re: 46 light switch
Post #2 here may help.
https://www.fordbarn.com/forum/showthread.php?t=132768
Old 01-09-2021, 07:42 PM   #3
FortyNiner
FortyNiner's Avatar
I've had better luck inserting and seating the shaft before turning on the mounting nut.
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 01-11-2021, 11:59 AM   #4
46woodie
GOT IT, thanks
