01-05-2021, 01:51 PM | #1 |
I'd never have dreamt this would be possible.
I started cleaning the oil pump for the Old 59 Flatty and i couldn't believe what I found.
I would have thought the oil pump would have been the last thing to have rotted out. Mart. |
01-05-2021, 02:02 PM | #2 |
Re: I'd never have dreamt this would be possible.
Now that is crusty! Must have been some acidic sludge in the bottom of that engine. How does the oil pan look?
01-05-2021, 02:09 PM | #3 |
Wow! That looks unreal. How can oil do that?
01-05-2021, 02:09 PM | #4 |
All condensation or other water ends up at the lowest level and the oil stays on top of it. Look carefully for cracks.
01-05-2021, 02:12 PM | #5 |
What’s a 59 Flatty?
01-05-2021, 02:41 PM | #6 |
01-05-2021, 02:48 PM | #7 |
Mart just use some JB weld epoxy to cover over those holes it will be good as new.
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
01-05-2021, 02:48 PM | #8 |
Mart,
It seems you have a fetish for "crust"....
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 01-05-2021 at 03:29 PM. |
01-05-2021, 03:21 PM | #9 |
01-05-2021, 03:29 PM | #10 |
Mart, let's face it. The stuff you open up are the ones most people just walk past. And then you go and post a video of it zooming up a hill with a bunch of high dollar(high pound?) cars. Nice oil pump by the way.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
01-05-2021, 04:48 PM | #11 |
I just went and had an initial scrape about in the bottom of the oil pan. It has some interesting sludgy deposits but luckily and hopefully there doesn't appear to be any corrosion That'll be tomorrow's job, to clean that up. Again, luckily I do have an oil pump I can put in it.
Mart. |
01-05-2021, 05:15 PM | #12 |
i was once trying to free up a stuck w2 halftrack motor. crowbar on the flywheel, bang! she let loose then felt fine. after tear down i found the oil pump was all that was stuck, and i had sherd off the drive forcing it to turn. oil pan was full of water
01-06-2021, 06:10 PM | #13 |
Hey Mart, how about a video of you brazing up that pump.
