Old 02-28-2019, 03:27 PM   #1
Dan 1939
Dan 1939's Avatar
Default Banjo Rear Gear Manufacturers
I'm looking for suggestions of where to buy 3.25 Gears for my 1939 1/2 ton pickup. Is there any that have bad reviews.
Thanks for any help,
Dan
Dan 1939 is offline   Reply With Quote
Old 02-28-2019, 04:08 PM   #2
supereal
supereal's Avatar
Default Re: Banjo Rear Gear Manufacturers
There are several sources for those conversions. C&G (800-266-0470) shows the 3:25
ring and pinion set for 35-41 pickup as 48-4209-F6 6 spine type.
supereal is offline   Reply With Quote
Old 02-28-2019, 04:27 PM   #3
Andy
I bought mine from Speedway. They were excellent.
Andy is online now   Reply With Quote
Old 02-28-2019, 07:10 PM   #4
rotorwrench
rotorwrench's Avatar
Most of them likely come from the same source. There were some Italian made one some years back that had the pinion quill manufactured too large a diameter to go through the bearing support bore. Some grinding was necessary to make those work. There were more recent ones that had too large a journal surface but we are talking only about .001" or a bit more too large.
I haven't heard any one complaining about gear sets for quite a while. Most go for the 3.54:1 sets. 3.25:1 is kind of tall for a pickup. It would be hard to get it going with a load on board.
Old 03-01-2019, 01:23 PM   #5
john in illinois
john in illinois's Avatar
I bought a set of 3.25s from Speedway. They are made by Motive Gear and very good quality. As mentioned I had to polish the first bearing part of the pinion so the bearing would slide to set preload. I think most vendors carry this brand.
John
john in illinois is offline   Reply With Quote
Old 03-01-2019, 01:56 PM   #6
38bill
38bill's Avatar
I purchased mine from Speedway. Speedway still lists their gear sets as Getz brand?
38bill is offline   Reply With Quote
Old 03-01-2019, 03:01 PM   #7
rotorwrench
They still list them that way but they are made by Motive Gear. There have been discussions on the HAMB about this.
