01-09-2021, 04:19 PM | #1 |
46 light switch
Ok, having problem keeping light switch knob from popping out of switch assembly. I insert, then give swift push inward. Latches but not securely. Pulls out of switch body when going to headlight position. What is correct way of inserting this into switch body???
01-09-2021, 04:26 PM | #2 |
Re: 46 light switch
Post #2 here may help.
https://www.fordbarn.com/forum/showthread.php?t=132768 |
01-09-2021, 07:42 PM | #3 |
Re: 46 light switch
I've had better luck inserting and seating the shaft before turning on the mounting nut.
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it Last edited by FortyNiner; 01-11-2021 at 02:27 PM. |
01-11-2021, 11:59 AM | #4 |
Re: 46 light switch
