Old 12-15-2020, 07:44 AM   #1
dspottss
Default 37 Replacement seats
Hello. New to this board and my 37 ford four door sedan. It is in remarkably good shape with the exceptions of the seats. I am not planning on taking this to shows only driving it on weekends and just for pure enjoyment. Is there an exact bolt in bench seat replacement from a later model ford? I have seen comments about Bronco's or Vans but would like to know the exact model and years if possible. Thanks for any help.
dspottss is offline   Reply With Quote
Old 12-15-2020, 08:26 AM   #2
deuce5wndw
deuce5wndw's Avatar
Default Re: 37 Replacement seats
Welcome aboard. I don't know of a bolt in seat but why not just take the originals to a upholstery shop and get them done?
deuce5wndw is offline   Reply With Quote
Old 12-15-2020, 09:13 AM   #3
Zax40
Zax40's Avatar
The factory seats can be rebuilt using modern foam and materials as long as the seat frame is not in too bad of shape. It is pretty amazing how comfortable and supportive they can be with the modern high density foam.
I redid the bench in my f100 myself with a Cartouche seat cover and it turned out great. It didn't cost me too much. Just cover, materials, snap ring pliers, and a weekend of work.
Zax40 is offline   Reply With Quote
Old 12-15-2020, 12:49 PM   #4
Kurt in NJ
Kurt in NJ's Avatar
Snyder makes springs
Old 12-15-2020, 02:03 PM   #5
dspottss
I guess I will go that route. I have received 2 quotes, almost identical, $750 for each seat. Too much for me. The one shop admitted it was almost twice the normal rate due to Covid. He said he is working 7 days a week and doesn't look like it will change. By the way the frame and springs are in great shape. I just haven't done this before. I am pretty handy so I just may watch a few YouTube videos and take a shot at it. Thanks everyone.
Old 12-15-2020, 03:05 PM   #6
maineford
In my opinion nothing looks right except the correct seat in these old cars
maineford is offline   Reply With Quote
Old 12-15-2020, 03:15 PM   #7
Mart
Mart's Avatar
Mexican blanket for a year or two till things quiten down?
Old 12-15-2020, 03:36 PM   #8
Zax40
Zax40's Avatar
I watched several videos on youtube. Got some good tips like use vinyl instead of burlap between the frame and foam. Use a cheap electric turkey carver knife to cut the foam (got mine for $2 at a thrift store). Use a 36 grit sanding disk to shape the foam on the curved edges.
Got my foam online from a place called Foam Factory. This is what I bought from them to give you an idea:
1 qty HD36 High Qual. Foam- Half Sheet-82" x 36" x 1" (seat back)
1 qty Lux High Qual. Foam - Third sheet -82" x 24" x 5" (seat bottom)
8 qty Fiber Fill Medium - 1" Thick 60" Wide x linear ft. (between foam and seat cover)
Old 12-16-2020, 10:22 AM   #9
dspottss
Thanks to everyone again for your help and advice. I will keep you posted on progress hopefully.
Old 01-15-2021, 07:08 AM   #10
dspottss
Need a little help. I removed and stripped both seats. Unfortunately I did not take pictures before I did this. Does the front seat cover attach directly to the wooden frame? Does anything else hold the box springs to the wooden frame? Thanks.
Old 01-16-2021, 03:12 AM   #11
swoopNZ
MEMBER EMERITUS
38 seats are similar.
Look around for prices to recover them.
A semi-retired upholsterer would be ideal.
Check the EFV8 roster for club members in your area.
Good luck.
Chris.NZ.
New Zealand.
swoopNZ is offline   Reply With Quote
Old 01-16-2021, 03:18 AM   #12
Tinker
Tinker's Avatar
I'd rather have some lumpy correct seats then a couple 80s aerovan seats.
Post some pictures of what you are asking if you can.
Old 01-16-2021, 06:15 AM   #13
ford38v8
ford38v8's Avatar
Anyone suggesting foam to replace the original springs hasn't the good fortune to have experienced the comfort of these seats on cross country trips.
Alan
Old 01-16-2021, 01:40 PM   #14
JayChicago
JayChicago's Avatar
Some good pics in this thread. Is a '40 but probably is similar, may be of some help.
https://www.fordbarn.com/forum/showthread.php?t=292950
Old 01-16-2021, 06:59 PM   #15
51504bat
51504bat's Avatar
Maybe if you included at least your general area someone might have a suggestion for another shop that is more in your price range. When I had the stock seat upholstered in my '39 p/u using flat vinyl with no spring or frame repair it was $300.00. Had the exact same price quote from another shop. Both known for quality work. More recently upgraded to a Glide Engineering frame. Cost to completely cover it with a sculptured vinyl was $500.00 including all the required foam, etc.
