09-28-2011, 04:01 PM | #1 |
Price for 21 stud engine
What would be a fair price range for a used 21 stud V-8 block, complete with pan, aluminium heads, and intake manifold, in good running condition?
09-28-2011, 04:06 PM | #2 |
Re: Price for 21 stud engine
What year? Where are you?
Charlie Stephens |
09-28-2011, 04:08 PM | #3 |
1936 with inset bearings
09-28-2011, 04:33 PM | #4 |
Alum heads on a lb block would be very unusual. All the alum heads I have seen were for earlier engines with flatop pistons. 36 lb engines had domed pistons and iron heads, there may have been some early ones with alum but I doubt it. 33-4 engines had alum heads.
09-28-2011, 04:35 PM | #5 |
I will add something else, if it is a lb engine and has been bored out, you may be in for a expensive rebore and sleave job on all cyl. They have thin walls and big bores do not last long.
09-28-2011, 04:48 PM | #6 |
09-28-2011, 06:02 PM | #7 |
All '36 passenger cars were built with aluminum heads, either with one of the variety of 40-prefix heads for engines with flat-top pistons or with 48-prefix heads for engines with domed-top pistons. (The conventional wisdom is that the 68-prefix heads were released so late in '36 that they are service parts, not used in production.) That many engines are encountered with cast iron heads decades later is attributable to the tendency for aluminum heads to be cavitation-prone when exposed to cooling water with high mineral content.
09-28-2011, 09:26 PM | #8 |
have you pulled the pan and seen that it has inserts??....i think there have been stories of blocks with lb stamped on them and still having babbitt bearing....good luck....300 or so for the engine??...Mike
09-28-2011, 11:14 PM | #9 |
Thanks for all the comments but I am not concerned about the heads or piston tops, I just would like to know the price range for the engine as described. So far the range is $300 to $1000. Is $1,000 about the top and $300 about the bottom??
09-28-2011, 11:48 PM | #10 |
Not all '36 LB engines came from the factoy with domed top pistons. I have an original '36 insert bearing engine that came out of a known original '36 1/2 Ton PU with flattop pistons. Who can really say what actually left some of those Ford assembly plants 75 years ago?
09-29-2011, 05:59 AM | #11 |
Depends on who's selling, who's buying, and where you are.
Has anyone actually sold an "LB" engine lately? I'll gladly buy every $300 "LB" engine in running condition that I can get my hands on. (Sold, $750, rebuildable, not running.) I hope everyone will remember this as the "good old days" when you could buy a good running flathead for $500 ... or less.
"Remember that when it comes to intelligence, half of all of us are below average." |
09-29-2011, 08:15 AM | #12 |
It's tough to give you a price range without you giving us more pertinent information about the engine, your location, if you are buying or selling, etc. I would not sell the complete LB engine that I have for any less than $1500.00 and I have no idea how this engine ran when it was removed. However, I do know this block is crack
free and there is little or no wear ridge at the top of each cylinder. Give us more facts about this engine for us to be able to give you a price range.
09-29-2011, 08:35 AM | #13 |
i thought i was pretty lucky with this 21 stud purchase 1.5 yrs ago for $350 and it was exactly as the guy represented it. this was my email to him recapping my understanding of the engine history......." you bought the engine from a swap meet 5yrs ago it had ford rebuilt stickers on it (validity of the stickers unknown), one of the water pumps is leaky, you used the engine to be able to move your car project around and it had limited use, it has been sitting in your heated garage for the last two years, it has cast iron heads (not aluminum) it has good oil pressure and does not burn oil. it does not have the carb or Generator, and you are asking $350 for it. you are recommending new gaskets and rings because it is old and you don't have a full history of it."
