Old 09-28-2011, 10:59 AM   #1
cuzncletus
cuzncletus's Avatar
Default radiator hoses 8ba to 59a
Nothing's ever easy. The necks on the thermo housings on my 8ba are much smaller than those on the 59a in my 39 sedan. Is there an easy rig cure or does anyone make hoses for this conversion?
cuzncletus is offline   Reply With Quote
Old 09-28-2011, 11:11 AM   #2
Butch11443
Butch11443's Avatar
Default Re: radiator hoses 8ba to 59a
Go to NAPA> They make a rubber reducing sleeve for the larger hose.
Butch
Butch11443 is offline   Reply With Quote
Old 09-28-2011, 11:41 AM   #3
Bruce Lancaster
The purpose made reducers are just right...long before they were available, I just cut the ends off of one 8BA hase and used them for adaptors! The new way is almost certainly better in offering a better grip on everything than the eaxterior of a hose.
Bruce Lancaster is offline   Reply With Quote
Old 09-28-2011, 03:20 PM   #4
TJ
TJ's Avatar
Tatom Custom Engineering; www.tatom.com, makes the 8 BA necks for the larger hoses. The phone number should be 360-424-8314. I used them on my 40 with an 8Ba and they worked great. Not cheap, but they look great.
Old 09-29-2011, 12:53 AM   #5
Matt in Alameda
I haven't been able to get Tatom's web site for well over a year.....I think they are history.....Matt in Alameda
Matt in Alameda is offline   Reply With Quote
Old 09-29-2011, 05:15 PM   #6
cuzncletus
cuzncletus's Avatar
Went to NAPA as advised. Parts #'s 900 and 901, 2 each, under hoses and belts look to be a simple and not too expensive solution. Thanks.
Old 09-29-2011, 06:08 PM   #7
Henry/Kokomo
Henry/Kokomo's Avatar
"Flathead Jack" Schneider makes water outlets for late model flatheads with 1.75" hose connections. Very pretty, well made and $45 ea. Makes an engine swap to an earlier chassis easier and looks nice when finished
Henry/Kokomo is offline   Reply With Quote
