Old 09-27-2011, 11:42 PM   #1
Trelpdx
Trelpdx's Avatar
Default 35 - 5 Window Door glass retainer alignment
Guys,
When installing door glass into the window retainers, how do I make sure the glass is positoned correctly in the retainer from front to back. What I mean, is the centerline of the glass even with the mid point of the retainer? I've never had glass in this car.
Thank you,
Peder
Trelpdx is offline   Reply With Quote
Old 09-28-2011, 12:50 PM   #2
TagMan
Default Re: 35 - 5 Window Door glass retainer alignment
The side window glass in my '36 3-window was exactly centered in the retainer (i.e. center line of the glass was in line with the center line of the retainer), if that helps.
TagMan is offline   Reply With Quote
Old 09-28-2011, 03:24 PM   #3
Gary Tosel
Gary Tosel's Avatar
I don't believe the 3W coupe has the vent feature that rolls the window back and then when you move forward and continue the window goes down same for a Fordor front window.
The original glass I have is 27" long on the bottom and the track is 21-1/4" long. From the front of the glass it is 2-3/4" and the back it is 7/8".
Hope this helps.
Gary Tosel is offline   Reply With Quote
Old 09-28-2011, 04:09 PM   #4
TagMan
Hope this helps.
Gary,
You are absolutely correct - I forgot about that. Sorry for the mis-information. I certainly didn't mean to mislead..........
Old 09-28-2011, 11:10 PM   #5
Trelpdx
Trelpdx's Avatar
Great, thank you.
Peder
