Old 09-27-2011, 08:02 PM   #21
Fe26
Default Re: $250 for switching R&P in banjo rear
There was an excellent and very informative article (with many pictures) posted on The Hamb a while ago.
Fe26 is offline   Reply With Quote
Old 09-28-2011, 06:20 AM   #22
PeteVS
PeteVS's Avatar
Originally Posted by Hoop View Post
"Install them with the lips pointed in towards the center of the car."
"The lip seals point towards the hub."
( ... I'm getting light-headed.)
It's my opinion that the inner axle seal is intended to-
1: Keep differential oil out of the rear wheel bearings and-
2: Giving the wheel bearing grease (if overpressurized from heat or ill advised use of the zerk fitting) a place to go other than out to the brakes.
IMHO
Don't never get rid of nuthin!
PeteVS is offline   Reply With Quote
Old 09-28-2011, 07:12 AM   #23
jimTN
The lip seals point towards the center of the rear end, their purpose is to keep the lighter liquid grease from going into the hubs and diluting the heavier wheel bearing grease there. The hub seals keep that heavy grease from getting out on your brake drums but will not do a good job of stoping the lighter liquid grease if it gets out there.
jimTN is offline   Reply With Quote
Old 09-29-2011, 09:02 AM   #24
Ralph Moore
Ralph Moore's Avatar
Well I guess I learned something new! I have yet to tear into my rear end because it came from a running car. Although I would love to upgrade it to later splined axles as depicted in the latest R&C magazine.
Ralph Moore is offline   Reply With Quote
