09-25-2011, 06:37 PM | #1 |
Difference in Fan Horsepower Costs
I just replaced my stock 8BA 3-blade fan with a flathead truck or Mercury 4-blade fan.
I'm curious as to how much horsepower the 3-blade ate and how much the 4-blade now eats. Does anyone actually know? No points awarded for guesses. |
09-25-2011, 07:22 PM | #2 |
Re: Difference in Fan Horsepower Costs
according to john lawsons book, none.
09-25-2011, 08:16 PM | #3 |
Can you tell me what page or pages that's on?
I see the section about the stock car fan on pages 12 and 13, but that doesn't answer my question. Last edited by Richard in Florida; 09-25-2011 at 08:22 PM. |
09-26-2011, 05:52 AM | #4 |
My book does not say "none". It does say that when operating the stock fan at 3000 or less RPM the power loss is almost impossible to measure on the dyno. If you can imagine connecting a 5HP, 3600 RPM, motor or engine to a fan it is not difficult to understand that a fan would have to be HUGE to take all the power a 5 HP motor produces.
09-26-2011, 10:00 AM | #5 |
sorry john, thats what i get for trusting my memory!
09-26-2011, 12:10 PM | #6 | |
Does your considerable experience suggest that the difference in drag between the two fans would be minor or more than that? I'm getting ready to make another mileage run; the first was made with the three-blade fan. I'm just trying to level the playing field so any results I get are meaningful. |
09-26-2011, 12:17 PM | #7 |
You didn't mention whether the fan is painted or unpainted.
KIM KARDASHIAN ISN'T FLAT, BUT MY MOTOR IS..... http://s818.photobucket.com/home/roglehr/index |
09-26-2011, 12:25 PM | #8 |
You're overthinking this. You will never notice the difference, especially in a normal driving mode.
09-26-2011, 12:28 PM | #9 |
Fans take more power to turn as the speed increases. Limiting speed is the speed of sound at the tip which causes blade stall as it get progressively faster. On the turbine helicopters I work on (Hughes/MDHI 500 types), the tail rotor takes 40 horsepower at 103% N2 speed with full pedal input (variable pitch like a prop). I would say in comparison, a 1951 Mercury fan at 3200 RPM will be in the neiborhood of .85 HP loss from engine function. It is an educated guess and the estimate is high but anywhere between 1/2 HP and .85 HP should be pretty close. It's not really enough to be worth mentioning.
Kerby |
09-26-2011, 12:31 PM | #10 | |
It's gold plated and has diamonds on it. I built and flew experimental airplanes for many years. I had a friend whose attitude was "warm it up, I'll fly anything!" He never bothered with numbers. He's dead now. Improper engine management on takeoff of a friend's just-completed project. Crashed onto the runway with full fuel. Last edited by Richard in Florida; 09-26-2011 at 12:42 PM. |
09-26-2011, 12:37 PM | #11 | |
Since easily 99.9% of the mileage run will be at 2500 rpm or below, it's probably safe to say the different fan won't matter. Thanks. |
09-26-2011, 09:22 PM | #12 |
Richard, is there enough room to run a thermostatically controlled fan clutch in there? ..B.
09-26-2011, 11:41 PM | #13 | |
And the idea of an ugly amp-sucking electric fan turned my stomach. The Mercury fan hub and four-blade fan are the perfect upgrade. |
09-27-2011, 03:18 AM | #14 |
I replaced the 4 blade fan on my C59A with a 6 blade truck fan. I did this because I'm running a small radiator. It definitely sucks more air, but I have not noticed any difference in engine performance. It is slightly more noisy.
09-27-2011, 08:08 AM | #15 | |
09-27-2011, 12:24 PM | #16 |
What is your altitude and barometric pressure?
09-27-2011, 12:52 PM | #17 |
Richard...what are you saving your amps for? Your grandchildren?
09-27-2011, 02:01 PM | #18 |
Would only have to worry about altitude and barometric pressure if the fan was painted like this
09-27-2011, 02:59 PM | #19 |
I always thought that the fan was for still air, when you are stopped. At speed the fan is working in moving air and not doing much work. With a 50mph wind coming into the grill the fan can't being much.
Bill |
09-27-2011, 03:02 PM | #20 |
09-27-2011, 03:05 PM | #21 |
Good point, Bill. So what you're saying is that if you are driving fast enough, the airflow will actually propel the fan and that will actually add horsepower rather than use horsepower. I guess a four blade fan will add more HP than a three blade fan.
09-27-2011, 03:50 PM | #22 |
If it is decided to paint the fan powder coating would be better than rattle can paint. Since the stock fan has a sharp edge on the blade powder coating would tend to round off the edge and give a more efficient cut through the air. Somewhat like a propeller. This has not been field tested but, I think the theory is correct.
09-27-2011, 04:34 PM | #23 |
With forward speed the fan is unloaded a fair amount. That's kind of a counter balance for the amount of work it takes the engine to pull it. It's just one more variable that changes the work it takes to spin one. We wax main rotor blades on the helicopters all the time but it only seems to aid with lift a very slight amount and waxing the top or high velocity side of the blade does help with packing or lift on the high pressure side more if you don't wax the bottom of the blade. We wax them more to keep corrosion in check than for lift or speed reasons. On a little tiny fan it won't even be noticeable.
Last edited by rotorwrench; 09-28-2011 at 09:06 AM. Reason: to correct terminology |
09-27-2011, 06:41 PM | #24 |
Mercury Fan Hub Bearings
Ran a temperature comparison road test today with the four-blade fan. Conditions were the same as they were during the three-blade test including OAT (within 2 degrees).
Overall, engine temperatures ran about 8 to 10 degrees cooler. However, I can feel wear in one or both of the hub bearings. Can these bearings be replaced? Are these bearings available, or might there be a new "modern" equivalent? Anybody done this? |
09-27-2011, 06:58 PM | #25 | |
Re: Mercury Fan Hub Bearings
09-27-2011, 08:51 PM | #26 | |
Aren't there TWO bearings in that hub assembly? I'd like to save this Mercury hub since my chances of finding another one are slim. |
09-27-2011, 09:24 PM | #27 |
The first fan bearing I changed I cut the one end to match the one being replaced. On the second fan I changed the bering on I measured and found there is enough room in the housing toward the fan so the shaft fit without shortening the shaft, the thin end cover plug fit with room to spare.
Vergil
Bigger fonts to aid in reading |
09-27-2011, 10:59 PM | #28 |
Does it look something like this?
09-28-2011, 05:57 AM | #29 |
09-28-2011, 06:51 AM | #30 | |
09-28-2011, 08:59 AM | #31 |
We refer to those types of bearings as a double row bearing. It has two rows of balls and double ball grooves in each race. Most of them are sealed but many have seals the can be removed for servicing. Those plugs on the front are commonly refered to as Willkie button plugs. We use them a lot in aviation to plug old unused holes in instrument panels and they are made in all sorts of sizes. They are named after Wendell Willkie who used buttons like them in his failed presidential bid.
JDL, thanks for that P/N. My Merc fans are still running smooth but the day will come when they aren't. 60-years is a long time for grease to be in a sealed bearing. Kerby |
09-28-2011, 11:02 AM | #32 |
