09-27-2011, 03:05 PM | #21 |
Re: Difference in Fan Horsepower Costs
Good point, Bill. So what you're saying is that if you are driving fast enough, the airflow will actually propel the fan and that will actually add horsepower rather than use horsepower. I guess a four blade fan will add more HP than a three blade fan.
09-27-2011, 03:50 PM | #22 |
If it is decided to paint the fan powder coating would be better than rattle can paint. Since the stock fan has a sharp edge on the blade powder coating would tend to round off the edge and give a more efficient cut through the air. Somewhat like a propeller. This has not been field tested but, I think the theory is correct.
KIM KARDASHIAN ISN'T FLAT, BUT MY MOTOR IS..... http://s818.photobucket.com/home/roglehr/index |
09-27-2011, 04:34 PM | #23 |
With forward speed the fan is unloaded a fair amount. That's kind of a counter balance for the amount of work it takes the engine to pull it. It's just one more variable that changes the work it takes to spin one. We wax main rotor blades on the helicopters all the time but it only seems to aid with lift a very slight amount and waxing the top or high velocity side of the blade does help with packing or lift on the high pressure side more if you don't wax the bottom of the blade. We wax them more to keep corrosion in check than for lift or speed reasons. On a little tiny fan it won't even be noticeable.
Last edited by rotorwrench; 09-28-2011 at 09:06 AM. Reason: to correct terminology |
09-27-2011, 06:41 PM | #24 |
Mercury Fan Hub Bearings
Ran a temperature comparison road test today with the four-blade fan. Conditions were the same as they were during the three-blade test including OAT (within 2 degrees).
Overall, engine temperatures ran about 8 to 10 degrees cooler. However, I can feel wear in one or both of the hub bearings. Can these bearings be replaced? Are these bearings available, or might there be a new "modern" equivalent? Anybody done this? |
09-27-2011, 06:58 PM | #25 | |
Re: Mercury Fan Hub Bearings
09-27-2011, 08:51 PM | #26 | |
Aren't there TWO bearings in that hub assembly? I'd like to save this Mercury hub since my chances of finding another one are slim. |
09-27-2011, 09:24 PM | #27 |
The first fan bearing I changed I cut the one end to match the one being replaced. On the second fan I changed the bering on I measured and found there is enough room in the housing toward the fan so the shaft fit without shortening the shaft, the thin end cover plug fit with room to spare.
Vergil
Bigger fonts to aid in reading |
09-27-2011, 10:59 PM | #28 |
Does it look something like this?
09-28-2011, 05:57 AM | #29 |
09-28-2011, 06:51 AM | #30 | |
09-28-2011, 08:59 AM | #31 |
We refer to those types of bearings as a double row bearing. It has two rows of balls and double ball grooves in each race. Most of them are sealed but many have seals the can be removed for servicing. Those plugs on the front are commonly refered to as Willkie button plugs. We use them a lot in aviation to plug old unused holes in instrument panels and they are made in all sorts of sizes. They are named after Wendell Willkie who used buttons like them in his failed presidential bid.
JDL, thanks for that P/N. My Merc fans are still running smooth but the day will come when they aren't. 60-years is a long time for grease to be in a sealed bearing. Kerby |
09-28-2011, 11:02 AM | #32 |
