09-29-2023, 07:07 PM | #1 |
Positive/Negative ground question
When I bought my 37, I noticed the ammeter was reading backwards. I found the battery in backwards, negative ground. I turned the battery around for positive ground, everything then worked fine. Now I have a 33 that somewhere down the line was switched to negative ground. I was going to leave it that way but I ordered LED bulbs for positive ground forgetting it is now negative ground. If I switch the battery back to positive ground is there anything else I have to change? It’s all stock except it has an electric fuel pump added.
Tim Carlig |
09-29-2023, 07:47 PM | #2 |
Re: Positive/Negative ground question
The LED bulbs I’ve bought were not polarity sensitive.
09-29-2023, 07:54 PM | #3 |
Ken, I ordered the headlamp bulbs you recommended from Amazon. These are the taillight bulbs I tried tonight, they asked if I wanted + or - ground bulbs. I forgot the car was negative ground when I placed my order
Tim Carlig |
09-29-2023, 07:58 PM | #4 |
I believe you will have to switch the terminals on the coil.
09-29-2023, 08:09 PM | #5 |
Only polarity specific items are effected by switching between positive and negative ground. Non-LED bulbs are polarity specific, as are radios and ammeters. Your '37 radio won't work on a negative ground, and as you observed, the ammeter works backwards (it denotes direction of current flow).
09-29-2023, 08:14 PM | #6 |
Tim Carlig |
09-29-2023, 09:04 PM | #7 | |
In your case, no switch is required at the coil (no way to switch anyway). The change in polarity takes place upstream of that coil. I like those distributors, especially if you use the later set of points. I just sent mine to 3rd Generation for refurbishment and the later points. There is an old adage that positive ground systems reduce corrosion of the car and its components. I have no idea if that is fact, or fiction. While you are making those changes, you might want to replace your battery cables with 2/0 wire cables with copper or brass washers. |
09-29-2023, 10:24 PM | #8 |
If I'm thinking clearly tonight, you'll need to pull the wire from the ammeter loop and push it through in the opposite direction.
Alan |
09-30-2023, 09:22 AM | #9 |
If you bought this bulb for the taillights it’s non polarity.
09-30-2023, 11:19 AM | #10 |
Nobody has mentioned repolarising the generator. Also the battery terminals are different sizes (if they are the original tapered type) so new cables may be required.
09-30-2023, 12:41 PM | #11 |
Ken, I bought them from LBcarco.com. They specified positive or negative ground, I was in positive ground mindset so that’s what I ordered. Forgot it was negative ground so they don’t work. I’m going to switch the car back to positive. Thanks.
Tim Carlig |
09-30-2023, 02:18 PM | #12 |
Ok. I also forgot that you needed the pins straight across and not staggered like the ones I pictured.
11-17-2023, 02:28 PM | #13 |
I know this is an older thread, but maybe can get some help without starting a new one. I have a 39 Ford Deluxe I bought a few months ago. It is very stock and 6v but is wired negative ground. What are the advantages/disadvantages of positive vs negative ground? The gauges aren't working now, but that might be another issue as a new factory style wiring harness has been installed. I have a 6v battery and the ground cable won't tighten correctly due to the post size. Also, the car has a Motorola 501a radio and aftermarket heater installed. Do they have to be wired with a 6v negative system in order to work? Neither of them work now. I'm sending the coil out to Skip for a rebuild and want to resolve these issues. Any suggestions and input apprieciated!
11-17-2023, 02:35 PM | #14 |
Bear in mind Skip had a knee replacement 10/23 and won’t be back in the shop for six weeks.
Tim Carlig |
11-17-2023, 03:24 PM | #15 |
I called him today, thanks though for the heads-up.
11-17-2023, 03:49 PM | #16 | |
I can't think of any advantage to switching polarity on a car that is to remain 6 volt. Lots of disadvantages: gauges, radio, etc, will only work as designed, positive ground. Are you sure the car has been switched to negative ground? Maybe just the battery was hooked up backwards. |
11-17-2023, 03:55 PM | #17 |
I'm not sure if the battery was hooked up backwards. The positive post has a battery connector with a wing nut on it and goes to the solenoid. Perhaps they switched it to negative ground because of the radio?
11-17-2023, 04:03 PM | #18 |
The early 6 volt cars were negative ground as it reduced corrosion problems. If the car is six volts, I would switch it back to positive ground. On the heater, you may have to switch the wires around to get it to work. The radio? We need more information. 6 volt Chevrolets (and other GM products) were negative ground, so if you have a radio from one of them, you have a problem. Other than that, it's probably a Ford radio, as I know of no one who makes and aftermarket 6 volt radio. I believe (I'm no expert on this) that the only polarity sensitive component in the radion is the vibrator. We clearly need more information about the radio.
11-17-2023, 07:33 PM | #19 | |
11-19-2023, 08:25 AM | #20 |
Switching battery polarity on the coil is not good.
